Topic: Dante issues with static IP using standard network
Hi, recently received Digiface Dante and having a few issues trying to integrate into our existing network. Currently have 2 devices on our network, which all are fed from our DHCP server. However, it seems the danteface is fixed at a static 10.X.X.X compared to our routers 192.
I cannot find anyway to change this through the Dante Controller which informs of the issue or otherwise. Any guidance appreciated! All other devices have successfully being applied correct IPs on the correct subnet.
Best,
Matt
Re: Dante issues with static IP using standard network
Solved my own issue. Had to set up a small network to the current static IP setting of the box, and with a bit of messing around finally enabled the Dante Controller to set the network back to DHCP.
