Topic: Input Select via Remote Control
as described in the manual, I have now changed the basic mode to "DAC" and can now also switch the source via remote control.
Currently I'm using these two input sources: "AES" and "Optical (SPDIF)".
But now I'm faced with this behavior:
When I press the "OPT" button on the remote control, the optical signal is available immediately.
But:
When I press the "AES" button on the remote, the display first shows "Source Select USB 1/2" and I have to press the "AES" button again directly (then the display also shows "Source Select Auto") and only then is the AES signal available.
My question:
Is the normal behavior for the AES signal (or the AES button) or what do I have to set where so that the AES signal is available directly with just _ONE_ press on the "AES" button ?
Brgs Andi
p.s.: big sorry if this was already dicussed 1000 times
