Topic: UFX 3 - Changing the sample rate often messes up the WDM devices
Hey,
I'm having an issue with the UFX 3 on Windows 11. Often when I change the samplerate from 44,1 to 48 or back, my WDM devices totally get messed up like some of them appear four times in the device manager whereas others only with one instance etc. Is this a known issue?
Re: UFX 3 - Changing the sample rate often messes up the WDM devices
Reduce the number of WDM devices to those that you really need. Might help.
Thanks Matthias but that doesn't solve the problem. I'm already using only 4 WDM devices.
You need 4 stereo wdm? Just try one wdm and see how that goes, if only for testing
