Topic: Are the filters on the ADI-2 DAC FS separate from what ESS offers?
Just swapped the RME DAC in for a competitor that uses the ESS ES9038Q2M, and the improvement is worth it. My frustration with the prior system was that none of the 7 filters on the ESS chip worked well for congested musical passages. ESS's Linear Phase Slow Roll-Off was great for sparser musics, but really choked when all the musici got busy, and the couple of filters handling that better still came up short. In contrast RME's DAC, with its default filter, handles everything with great clarity. It looks like the RME DAC's filter set isn't those  built into the Sabre chip. Is that right? Or is this due to some other aspect of RME's design?
Re: Are the filters on the ADI-2 DAC FS separate from what ESS offers?
And the difference between each reconstructive filter was clear as the difference between night and day? wink
As a middle-aged man I would love to hear the high frequency drop that NOS has at 20 kHz so that I could properly ABX test it! lol
Night and day? No, more like distinct shades of gray. I'm approaching 70, with a slight ringing in my ears since someone tossed a fire cracker right next to me in an arena hallway at an Alice Cooper show 50 years ago. Filter settings make a significant difference in clarity of tone for me -- whether a reproduced guitar or piano string sounds distinctly real. Looking at graphs of the effects, I wonder if it has more do do with ringing and/or frequency alignment in time than their high frequency roll off differences -- which in theory I can't hear too. wink
4 (edited by KaiS 2024-09-21 13:04:23)
Some of the filters are from RME and loaded into the ESS chip.
It’s mentioned in the manual, see below.
A Reconstruction-/ DAC-filter is a compromise between frequency response linearity, impulse response and aliasing artifacts.
The standard ESS “Sharp” filter tends to optimize towards freq. resp. and low aliasing.
Try the SD-LD, SD Slow (and partly Brickwall too), I hear them as better differentiating the higher instruments like shakers and hihats, and even have a better room definition.
NOS is throwing freq. resp. and aliasing over board, in favor of a perfect impulse response.
I don’t mind the high frequency rolloff, it’s subjectively compensated by good impulses.
But the audible amount of aliasing noises is fogging the sound way too much.
This is for 44.1 (and partly 48) kHz sample rate, above I don’t hear any difference.
Not all filters are available in all ADI-2 versions, so check with your device what’s offered.
ADI-2/4 Pro SE (=ESS) has:
SD Sharp, SD Slow, Sharp, Slow, SD LD, Brickwall, NOS.
Silver face ADI-2 Pro (AKM) has:
SD Sharp, SD Slow, Sharp, Slow, NOS.
Watch out, same named filters between AKM and ESS are not the same, except for Sharp (which is very close, sonically indistinguishable) and NOS.
From DAC manual page 58:
Unlike the AKM chip the ESS chip supports loading of custom filters. RME has calculated the filters SD Slow and NOS for the ESS chip, the filter coefficients are transferred to the chip during operation. On this occasion the not very popular SD LD has been replaced by the often requested Brickwall, which was also calculated and programmed by RME.
5
Neither can you hear the ringing, which only happens at half sample rate frequency. Plus neither guitar, piano nor strings include any frequencies that could excite ringing.
@KaiS
Maybe a little correction:
If I reset my ADI-2 PRO FS R to factory settings, SD SHARP (minimum phase) is the default filter (not SHARP). I would assume the ADI 2/4 PRO behaves identically?
7 (edited by KaiS 2024-09-21 19:39:50)
bejoro wrote:
@KaiS
Thanx, I deleted the false “default“ entries, as I have no overview about this.
SD Sharp is a good choice too that I like sound-wise.
Personally I tend to prefer the minimum phase filters about the linear phase.
I assume the pre-ringing of the linear phase filters is what I receive as smear.
Natural percussive instruments don’t have this, as there can be no sound before the drumstick (or whatever) excites the sound.
Thanks! Switching to SD Slow makes brush work on cymbals about twice as clear as with the default SD Sharp.
The default SD Sharp on the RME already sounded distinctly better than the brand I was using before with any of its 7 presumably stock ESS filters (including what it called "Minimum Phase Fast Roll-Off" -- same as "SD Sharp" right?).
Trying to get the terminology right. Wondering if "ringing" has more than one meaning in different contexts. In standard graphing of DAC filtering, there are smaller waves before and/or after the main signal, implying the signal is smeared a bit temporally. I've seen that written up as "ringing." Not at all sure that these graphs are illustrating the difference that makes a difference to what I hear. There are some on the audiophile boards claiming that none of us can hear filter differences at all, folks preferring their technical theories saying we shouldn't to obvious experience that we do (although, granted, maybe they themselves don't). I'm curious to know the proper technical description of the source of the differences.
As a guitar collector, I have a decent sense of whether a reproduced guitar tone has realistic detail to it's attack and harmonics. What is it about a struck guitar or piano string (or cymbals for that matter) that make the realism of reproduction so sensitive to DAC filter implementation?
10 (edited by KaiS 2024-09-21 19:57:06)
Every percussive signal has high frequency content that might be effected by the filter characteristics.
The whole issue is complex, and a simple graph doesn’t necessarily represent everything that happens, might even be misleading.
What looks like “ringing” in the impulse response e.g. might simply be the result of filtered out higher frequency components, not added resonance.
Finally the ear decides.
Check these 2 videos for a deeper insight, they are brilliant:
Monty:
https://www.youtube.com/watch?v=cIQ9IXSUzuM
Dan:
https://www.youtube.com/watch?v=-jCwIsT0X8M
Monty:
Thanks again. Just watched Monty's video. Enjoyed it; nicely done. Informative in regards to sine wave reproduction. Yet says nothing about the why you and I and others hear obvious differences between different filters.
A simple signal, like a recording of a flute or vibes, will come through pretty nicely on just about any system. Those are instruments producing notes relatively close to clean sine waves. Does the sine-wave-based analysis scale to complex musics, or is this like the three-body problem in astrophysics, where the complexity compounds far beyond what our current maths and analyses can handle, once more than a few simple sine waves (or two planetary bodies in the astrophysics) are involved? Intuition might tell us "Well, we have the math for two celestial bodies, so we can just use it for three." Or in this case "We have the math for N sine waves, so we can just use it for N+1." But math and logic don't always simply scale that way for complex systems.
Look at first video from about 17:20.
Percusive signal has fast change of value and so it has high frequencies well above 20 kHz. Similarly like square signal. The frequencies above 20 kHz are filtered out before A/D, so everyting i OK. (Look what signal gets in to AD and what signal gets out from DA.) But that means, that percussive signal has frequencies up to 20 kHz. So, different filters may give different results. As they differ in handling high frequencies. (Not, only. That is sort of shortcut description.)
When I write 20 kHz I mean half of sampling frequency. Or little bit less.
13 (edited by KaiS 2024-09-22 00:56:32)
I suggest not to create your own hypothesis’ or theories, but try to dig deeper into the existing ones.
Digital and analog audio signal transmission isn’t black magic, fortunately, but completely understood from the scientific perspective.
The two videos very competently cover some of the most important parts of digital audio, and demystify some points that are often misunderstood.
If you’re interested, watch them until you really get their informations.
Audio signal processing is deterministic and reproducable, you exactly know what comes out for a given input, and there is no unknown interaction between multiple parallel signals.
The other way round: the interactions, like aliasing noise and intermodulation distortions, are again predictable, for any number of audio objects, e.g. sine waves.
Music, of course, has a higher complexity than a few mixed sine waves, but still the result is scientifically fully predictable for any given moment of that ever changing signal.
Fortunately quality systems like ADI-2 are so close to perfect, that we are very close to in=out, in regards to what is audible to a human.
In=out is certainly true for sample rates of 88.2 kHz and up.
44.1 kHz and the resulting theoretical upper limit of 22.05 kHz for 1:1 digital sound transmission, and the filters that practically need to reach further down, are just close enough to our hearing capability that some changes to the sound become audible.
Regarding filters:
A filter (be it analog or digital) changes a signal, this is indeed it’s intended purpose.
That can come on cost of sound changes.
DA-filters typically are built to minimize audible side-effect of their job.
Minimize means this side-effects are not zero.
To judge the audible side-effect it’s easiest to listen to find your personal preference.
Theory and measurements can’t replace the listing, it’s the other way round:
Once you found you favorites ones, you can have a look at the measurements to find a correlation.
And– if you can’t hear a difference there is no relevant difference for you.
ADI-2/4 Pro SE BTW is great for such a filter and sample rate evaluation, as it can be feed directly with a fully analog signal from a vinyl disc.
ADI-2 Pro can do the same with a phono preamp fitted.
KaiS wrote:
bejoro wrote:
@KaiS
I was using SLOW (linear phase, AKM) for a long time. But I noticed a disturbing high frequency artefact. One example of an audible effect was a strange "squeakyness" of violins in symphonic orchestra recordings (good recordings). There were other straining high frequency effects in different recordings with SLOW.
I switched to SD SHARP or SD SLOW (minimum phase, AKM) and the "squeakyness" was gone. Other recordings sounded more natural and less straining with the minimum phase filters. Now SD SLOW is my choice for everything. With older rock&pop recordings sometimes I change to SD SHARP. SD SHARP seems to be more forgiving regarding recordings of lesser quality.
Of course all this with 44.1 kHz material (48 kHz). At higher sample rates from 88.2 kHz and up I am not sure if there is a difference (maybe imagination). You also mentioned that you are not able to detect any differences at higher sample rates.
15 (edited by whit 2024-09-23 19:34:30)
With all respect, that first video claimed that things are already perfect at the CD sample rate of 44.1. Yet we know from experience, and your next statement, that many of us do hear better musical reproduction at higher sample rates.
So our expert is clearly wrong about the science he's presenting, when he claims that 44.1 is already as perfect as we can possibly hear.
I'm an old man. The musical tonality difference I (and many others) hear is far below 20 kHz. The filter choices, on now three different ESS-based DACs I've used here, are audibly different to me. It's not just marginal, not just at the highest frequencies (which I can't hear anyway). Of the 7 stock ESS choices on their recent DACs, none sound quite right to me. Good vinyl with a high-end cart and stylus still provides better realism than 44.1 kHz signals through them.
The ADI-2's custom SD Slow filter finally produces a DAC circuit that's as pristine as the best vinyl pressings (assuming of course good engineering in the recording studio). Your team has pushed the art ahead of the science -- at least the science as represented in that first video, where the kid giving the presentation is so proud of his perfect theory that he persists in it despite real-life experience showing it to be, in the extended claims he makes for its perfection, incomplete. Denying evidence for the sake of preferring a theory, in its tight logic, has often held science back. As Thomas Kuhn's Structure of Scientific Revolutions showed, a generation schooled in particular doctrine often never surrenders it. It then takes a new generation to advance to better understanding.
Switching DAC filters causes audible tonal differences, not just near the high-frequency cutoff. There's surely doable science as to how. I'm on the side of science here -- and truly admire the ADI-2's scientific and artistic achievement. But I don't think we should accept the scientific project as complete until it explains what those of us with deep experience with listening to and playing music can clearly hear. Science still has work ahead of it. People thought physics was done in the 1890s too. It wasn't.
With complexly interacting components reproducing complex musical signals, we may be were we need to look at emergent features, in accord with complexity science: https://complexityexplained.github.io/. As George Box said, "All models are wrong, but some are useful."
@whit You have to distinguish what is obtainable in theory and what real implementation in flesh brings....
Car may drive, has four wheels, motor, streering wheel and so. Some drive better, some drive worse. Even if they use the same wheels, motor and so. Even subtle details may play role.
The same with interfaces at 44.1 kHz. Even using the same advanced DA chip may bring different results. Even if they use the same filter. Also analog part contributes to the result. And the way jitter is handled/eliminated.
This is not the case at all.
Did you conduct a proper double-blind testing? And even if you did, filters are characterized not only by their frequency response, but also by their phase response, which can lead to audible differences. No magic here.
There is no good vinyl. And please define "realism". If you claim that artifacts such as motor hum, detonation, stylus noise, clicks and pops make the reproduced sound closer to reality, then most will disagree.
OMG.
Typical audiophile rhetoric.
The case is much more complex than I thought initially.
18 (edited by KaiS 2024-09-27 06:23:42)
whit wrote:
..With all respect, that first video claimed that things are already perfect at the CD sample rate of 44.1. Yet we know from experience, and your next statement, that many of us do hear better musical reproduction at higher sample rates.
From the early days of digital I had the audible experience that 44.1 kHz has it’s limitations, in my work as a recording engineer, no doubt.
A simple flip of a button on my recorders reveals that.
But it had never been night and day, and I for sure being not tempted the tiniest bit to go back to producing music on linear analog media.
Nonlinear DAW reveals so much better results, technically and more important, musically.
And I will keep my hands off producing vinyl discs for my clients, with all the problems and limitations inherent to the format.
whit wrote:
… As George Box said, "All models are wrong, but some are useful."
Science uses theories (or models) that might proof wrong or incomplete in the long run.
Technology uses plans and calculations with real world results that either work or not.
Digital signal processing is fully understood, no surprises ahead.
Important parts of it were developed even almost a century ago, when no digital audio was in sight (Nyquist-Shannon-theorem)!!!
Final remark: I do listen to vinyl discs on a regular base - for the music, not specifically for the sound.
Which doesn’t mean I don’t want the best sound possible.
Never claimed "magic" involved. Yes, I'm curious about the theory of how filters produce such obvious differences. Had time yesterday to watch the second recommended video, which brought in how filtering introduces aliasing. That's the sort of understanding I'm after.
The anti-audiophile response of "did you do a double-blind test" is unoriginal. The bias against audiophiles that predictably gets expressed in such cliches in online discussions is just weird. Yeah, I love music. Yeah, I can hear the differences in equipment. I also have some background in experimental psychology. Look up "change blindness." Obvious differences when two visual images are placed side-by-side are commonly missed when the two images are viewed in sequence. And we're got far more of our brains devoted to the visual than the aural. So doing A/B comparisons in the double-blind way is going to miss even large scale differences obvious to most everyone when comparisons are side-by-side. I've found, for instance, that in comparing speakers or amps, putting the same signal through two different ones at once make obvious differences which are not so apparent playing through them sequentially.
Virgin, unworn vinyl with a good cart and phono pre-amp. What I'm after, in particular, is whether guitars sound real. My comparison is with a lifetime's experience both attending shows and playing. I know what's realistic harmonics out of a well-attacked string. It's a matter of recognition. You can get there with digital and a good DAC, or with analog an a good cart, needle and pre-amp. As for recording engineers' preferences, there are those who work well with one set of equipment, obviously, and others who work well with another -- as with any instrument of artistic expression. Sturgeon's Law applies in this area too -- most engineers, as with most musicians, aren't that good. But the truly good ones -- beautiful stuff, done on very different sorts of instruments.
One may compare two pictures at time. One can hardly compare two complex stereo signals at time so that it has any real relevance. It will always sound slightly different. And those four signals will interact. And the room plays role and so on....
The only way is blind A/B test using the same equipment, but one that is tested, at the same position.
21 (edited by KaiS 2024-09-27 08:33:12)
An audio comparison “side by side” would be a much stronger request and one step farther away than “blind A/B” from what I see at “audiophile” discussion, where comparisons are claimed with up to years between checks (“I had it but sold it”), different levels, different music etc. pp.
Practically I have no idea and would be interested how audio “side by side” can be executed in most cases, like filter comparison.
Regarding sound of natural instruments on recordings, from my point as recording engineer:
A recording is by no means the original, more like an as nice as possible photo, and the result is influenced by a dozen and more parameters.
Even the artist himself makes the same piece sound different on every take - intentionally or not.
You are right that the initial “attack” phase of any sound is the most important part for identifying it.
This is where a DA-filter can vary:
The form of the impulse, the first transient.
This happens in the high overtones only, but those largely influence how we subjectively receive the rest of the spectrum.
22 (edited by ramses 2024-09-27 07:12:29)
This is because this group of people turn out to be very resistant to advice in online discussions and do not understand that psychoacoustic effects must be eliminated in hearing tests by blind and double-blind tests.
If you don't use the correct measurement methods, then you come to wrong results and conclusions.
On such a basis, it is impossible to have a pleasant and fruitful discussion.
If someone then vehemently defends their false findings, as happens in almost all discussions with audiophiles, then they should not be surprised at such statements.
This is not to imply that you do the same, I just want to explain to you how such statements come about. Not because of marginalization, but simply because too many such exhausting discussions have already been held.
Psychoacoustic is also the main reason in this industry to sell overpriced solutions or solutions that are not worth it.
If you don't test properly, then anyone can simply talk you into something and hi-fi sellers, who don't know any better themselves, can sell wonderfully on this basis once the buyer's imagination has been stimulated accordingly and the desire to buy has been fuelled. And what is expensive must ultimately also be good and what was expensive is defended accordingly and this is where the circle closes.
@Whit
Double blind test is the only way to get relevant results about object of study. Not only in acoustics, but many other fields.
Even side by side comparison has to be organized as double blind test to be relevant. If the differences are subtle and not clearly obvious.
The trick of this so called High-End-HiFi industry is to put the customer into a state of constant uncertainty. Magazines, blogs, reviewer, influencer, fantastic marketing stories etc. they all repeatedly suggest that you have to find the right gadget to get the "perfect" sound. And because you should trust "your own ears" the customer will never succeed. And even if he/she does, he/she will never know, therefore constant state of uncertainty.
A perfect basis for selling anything fancy or expensive, regardless of its actual effect on playback quality.
Well put
Totally agree.! I dont post much here anymore, but I read everything. So I see people spend alot of time here convincing "audiophiles" Their logic is collapsing. Im concluding more and more to ppl just want to be fooled. Its just like love and money. Give it to me and Ill accept anything.
