1 (edited by Apfel 2024-09-25 10:36:39)
Topic: Fireface 800 and MacOS Sequoia
My setup (iMac M1, Fireface 800, Logic Pro X) is still running on Sequoia 15.0 without problems! I have the Fireface 800 connected via the usual two (original Apple-)adapter daisychain. Latest driver 3.41 and firmware 2.77 of course.
Additionally all UA-plugins are running. Wavelab Elements 11.2 (which I rarely use) also.
I didn't have to reinstall or update or reactivate anything.
Re: Fireface 800 and MacOS Sequoia
Great news!!!!
Thank you for sharing the information!
Fireface 800, MacBook Pro M4Pro, macOS15.5, Logic Pro 11.1.2
3 (edited by Apfel 2024-10-04 07:46:51)
Sequoia 15.0.1: works!
4 (edited by quattroquarti 2024-10-04 16:14:33)
Upgrade here too: everything ok!
No apparently issues here either with a FF800 and UFX on a M1 Studio.
Sequoia 15.1: still works!
Yeah!
Top news!!!
Good morning, I also want to give my testimony: My Fireface 800 connected with the usual two Apple cables to a Mac mini M1 with Cubase 13, it works great, it is already the third OS update without problems and without having to change anything in the setup, I performed the normal Apple update and when I restarted everything works wonderfully... thank you mother RME for giving us this magnificent Fireface 800, as soon as possible I will update with something more recent like 802FS or UFX, RME is a guarantee of functioning, in my studio has always been active for many years without ever a problem (I only changed some capacitors in the power supply a few years ago, €5 cost and easily replaced by me)
Sequoia 15.1.1: works!!!
Yeees!
I confirm that it works well under Sequoia (15.1.1): I had to change the Firewire port on the back of my Firewire 800 copy so that it would be properly recognized: phew!
MacPro 2 X 2,66 Ghz with 12 Go RAM & Fireface800 X 2 _ Digital Performer 8.07 _ Kontakt 5 _
15.2: thumbs up!
Yeah!
This is a beautiful news!
Thanks, Apfel!
I don't think anything will change with further Sequoia updates. Might be different with MacOS 16.
15
Agree. Also Apple could easily kill anything else (Kerne Extension) but FireWire - they have total control over this. We have to wait and see what they will do.
15.3: running!
Apfel wrote:
15.3: running!
Toooooop!!!!
Thanks Apfel!
Ciao!
Apfel wrote:
15.3: running!
Can you help me with this I got a new iMac it’s 15.3 but can’t see my fireface 800
19 (edited by waedi 2025-02-09 02:20:27)
alanpara wrote:
Apfel wrote:
15.3: running!
Did you check the driver extension switch ?
No will check this today thank you
Can anyone help me if I dm them or something or maybe link me with a page that just checks off all settings. Within my iMac the log in and extensions it’s showing 2 items one is Google llc this is clicked on and also rme GmbH which I think is what I need to pop up but still not showing my fireface800, any help much appreciated
Yea this is showing and switched to on
alanpara wrote:
Apfel wrote:
15.3: running!
Either the driver might not be installed correctly, or the unit is not recognized (for whatever reason) at all.
If its related to driver:
1) Set your Mac to reduced security in Startup Security Utility as you need to install kext drivers.
Described here: https://rme-audio.de/rme-macos.html
And here: https://rme-audio.de/reduced-security-mac-m-series.html
2) Reinstall the drivers again
3) If it still doesn't work, in terminal try a:
kmutil trigger-panic-medic --volume-root '/Volumes/YOURVOLUMENAME'
where YOURVOLUMENAME is the name of - your volume wink. Usually Macintosh HD.
4) Reinstall the drivers again
“Do It For Her”
Thank you so much this looks promising i will try this as soon as i get home from work today :-)
15.3.1: works!
26 (edited by quattroquarti 2025-02-11 15:03:09)
Apfel wrote:
15.3.1: works!
Goooooooo!
smile
thank you so much guys :-) i dont know what exactly fixed it but its showing now, i have audio coming from spotify to check the sound then apple music and its struggling to process it or something its crackly and glitchy. i presume this is now settings within it if anyone can help, i cant remember what i previously had set.
i have just found out that its my behringer ada8200 that is causing the interference, glitch and other playing problems. the audio seems fine now but when i turn on the adat it starts the problems. any help at all much appreciated :-)
15.3.2: everything is still fine!
30 (edited by quattroquarti 2025-03-13 11:55:31)
Top!!!!!
15.4: works!
smile
32 (edited by Apfel 2025-04-01 14:49:54)
Same here. Thanks!
But beware! The configuration is reverted to automatic system updates with this update. I had to reconfigure this. I don't want automatic updates and never wanted for obvious reasons.
Apfel wrote:
But beware! The configuration is reverted to automatic system updates after this update. I had to reconfigure this. I don't want automatic updates for obvious reasons.
Yes. After macOS reboot, my system alerted me about this new configuration to automatic system updates. Of course I also reconfigured this setting. No automatic updates, thanks.
smile
34 (edited by Apfel 2025-04-01 15:00:07)
Also, after reboot there was a screen saying "Welcome to Sequoia" or something, like a fresh installation. WTF?
35 (edited by quattroquarti 2025-04-01 15:04:49)
It's true...
roll
15.4.1: smile
Top!
smile
15.5: works!
smile
Yep! Thanks for going ahead!
