Topic: ADI-2 Pro FS R BE as a Switch
I recently purchased the ADI-2 Pro FS R BE to act as a switch in my system. I currenlty have the ADI-2 hooked up to active Dutch & Dutch 8Cs digitial through the breakout AES connection. I have a HiFi Rose RS130 on the breakout AES input. By setting the ADI-2 to pass-through I've been able to listen music with no issues. My problem has been trying to listen to the TV. I currently have the ADI-2 analog XLR inputs hooked up to the XLR outputs of my JBL SDP-58. looking at the screen of the ADI-2, I can clearly see that the analog signal coming from the JBL is coming through. Setting the ADI-2 to Pre-amp and the Digital Out Source to both Main Out or Default isn't producing any sound. The center channel of th JBL SDP-58 is producing sound and I can also see the visiual cues from the ADI-2 display that sounds is coming through the XLR inputs. Why am I unable to hear any sound coming throught the AES outputs? Any help resolving this issue will be greatly appreciated.
