What's connected to HW inputs (TM FX, top row) is always passed to the DAW/application.
If you do not see an input signal in the DAW, I pretty much assume, that you already do not see an input signal in TM FX.
Maybe you forgot, that on each MADI device you need to configure routing as well (not only in TM FX) …
You need to configure on the SSL which
- of the MADI channels shall be routed to the outputs of the SSL
- inputs of the SSL shall be routed to MADI channels and which
Besides this, all devices have to be configured to use the same
- MADI frame size, 48 or 96k (the latter if you intend to work with double speed as well)
- number of MADI channels, either 64 (or 56 when pitch is being in use)
MADI ID is not relevant if this is the only device and when you do not need to distinguish several devices in a chain, for example for remote control or delay compensation purposes.
