Re: ADI-2 Pro/DAC, 2/4 Pro SE - Models, Differences and Release Dates
rawac wrote:
Topanga_Dreams wrote:
And the TRS output on the back is also balanced?
User Guide wrote:
21.2 Line Out TRS 1/2
The ADI-2 Pro has two impedance balanced, short-circuit protected analog Line outputs ... Using a stereo (TRS) jack the output uses two 100 Ohm resistors internally to achieve impedance balancing. Using an unbalanced mono (TS) jack ring is connected to ground automatically, the output then operates unbalanced.
Mac Mini M2 Pro 16GB RAM - RME FIREFACE 802 - LOGIC PRO
52 (edited by kradzero 2022-08-01 14:40:09)
Hi everyone, I have the ADI-2 DAC connected to the Focal SM-9, purchased on the advice of this forum smile Very happy with the decision I made!
I have an opportunity to purchase the ADI-2 FS (https://www.rme-audio.de/ADI-2-FS.html). My main interest for this is in a separate system as a headphone amplifier. I know this is an audio interface and basically (probably) overkill, but I like to buy gear which allows me the flexibility to re-use in future setups.
The idea is: Oppo Sonica DAC (XLR pre-out) -> ADI-2 FS (XLR in) -> headphones (front port)
My questions:
1. Is the headphone amplifier section the same as/ at least as good as the ADI-2 DAC section?
2. Any issues with using the analog XLR inputs to send a signal from a streamer/DAC? Just that - in hi-fi - used to seeing RCA out from DAC to pre-amp and so forth.
Thank you all for your time smile
All
Just wanted to let everyone know that I purchased the ADI-2 DAC FS from Amazon Canada on 07/22/2022 and even tho it indicates an ASIN number of B081CWQXGD (per the spreadsheet this should be a 12/2017 model) - mine has this ASIN but shipped with the new ESS chip - my serial ends with a "C" - so it seems that we have another variant of the ADI box out there.
Cheers
VP
Does anybody have an answer to this: when I use the B/T eq encoders on front panel, whatver is changed is NOT reflected on the graph of the full parametric EQ.
Well, i have two of these dacs and in one of them it shows and the other no.
I have checked the manual, i made sure OF COURSE all eq settings are enabled…
It’s a mystery !
Anyone has an answer???
55 (edited by KaiS 2022-11-01 00:47:47)
It’s a mystery !
This works from ADI-2 DAC V49 and ADI-2 Pro V113 Firmware, and up.
There‘s been one or two FW versions before where B/T already was integrated into PEQ, but displaying the curve had minor quirks sometimes.
Originally B/T was separated from PEQ, that‘s what you see on one of your ADIs.
I suggest to install the latest FW‘s on both ADI-2‘s.
https://ibb.co/qdH57Rd
So which one i have?
57 (edited by ramses 2024-01-30 12:18:01)
So which one I have?
This is explained in the first post. According to the photo, you have an ADI-2 DAC FS. According to the table (1st post in this thread), there are 2 of these devices. It can either be a model with AKM or ESS chip. The text also states that only the model with ESS chip has a D/A filter called Brickwall.
Just check whether your device has a Brickwall filter, if so, then you have an ESS chip, otherwise AKM.
Added information for the ADI-2/4 Pro SE, see 1st posting: https://forum.rme-audio.de/viewtopic.ph … 06#p165706
Hi all,
Before I buy it, I would like to be sure that the ADI 2 DAC FS can be set to 10V output on the two rear XLR outputs so that it is a perfect match for my power amplifier (Purifi HPAS400ET need 10V input sensivity to reach full power).
Is it possible? If yes, how I can do it?
60
10V is +22.2 dBu, the DAC is referenced to +19 dBu, but can reach +21.5 without distortion. If you think you will need full power then an ADI-2 Pro or ADI-2/4 Pro with its +24 dBu XLR outputs might be better suited.
61 (edited by markoveter 2024-06-28 13:28:26)
10V is +22.2 dBu, the DAC is referenced to +19 dBu, but can reach +21.5 without distortion..
Tell me if I’m correct:
- 10v is required by the power amp for full power;
- But 10V out of the DAC mean full 100% volume pot; and full power out from the power amp mean 400W and my speakers are 250W. So i think I dont need such full power and such high SPL;
- Since I need good listening level with  volume pot at 50-70% I think 5 / 8V could be more than enough
It is right?
62 (edited by KaiS 2024-06-28 16:30:21)
It is right?
Absolutely.
With music and home use you typically don‘t go full power on an amp, more like in the few watts ballpark.
Or might be you have VERY insensitive speakers like the famous old Ohm F and still want to listen loud - at worst you loose 1/2 dB, that‘s not much.
Anyway, considering the ADI-2/4 Pro SE still can make sense.
There are a number of extras, e.g. you can connect a vinyl turntable to it.
BTW:
Volume Pot at 50% is just about 1% of full power!
Volume 70% still is only ca. 10% of full power - assuming the preamp puts out 10 V at volume pot 100%.
63 (edited by markoveter 2024-06-28 16:39:11)
So…
- if 10V is +22,2 dBu, how much volts are 19 and 21,5 dBu?
- and how should the ADI 2 FS be set to reach +21,5 dBu?
https://sengpielaudio.com/calculator-db-volt.htm
65 (edited by KaiS 2024-06-28 17:08:38)
So…
10 V = 22.2 dBu
9.2 V = 21.5 dBu
6.9 V = 19 dBu
To reach 21.5 dBu on ADI-2 DAC’s XLRs simply turn up it‘s volume to +2,5 dBr when the unit is in factory default settings, say Auto Ref Level is on.
If you want to manually select the reference level - not suggested - use +13 dBu.
The nominal ref. level references to the RCA out, XLR is 6 dB higher (double voltage), so nominal 13 dBu is 19 dBu at the XLRs.
Enough number crunching confusion? smile
BTW:
With real speakers and music, most power amps do not reach their full power all the time.
Speakers are so called “complex loads”, even act as generators themselves.
This means the power amp needs some amount of it’s power to eliminate the energy stored in moving membranes, and load and unload components in the x-over.
So, if you leave the power amp a little bit of headroom you will be rewarded with a cleaner sound.
Yes, very clear, thank you!
But, could you better clarify this?
67 (edited by KaiS 2024-06-29 23:59:47)
KaiS wrote:
The power amp needs some amount of it’s power to eliminate the energy stored in moving membranes, and load and unload components in the x-over.
A real world scenario:
Imagine the amp just pushed the speaker’s woofer membrane with 200 Watts of power outside, because the music (e.g. a bassdrum punch) asked for it.
The very next swing period of this same bassdrum sound is much smaller, as the real sound is decaying fast after the beater had hit the drumskin.
The typical woofer is much less dampened than a drum, so it tends to, once pushed, oscillate on for several periods.
98% of the energy the amp had pushed into the speaker is stored there in form of mechanical energy, in compressed or decompressed air inside the housing and the spring-effect of the woofer’s suspension.
Only 2% (real figures) is converted into sound (10-20 % at best in a very big horn speaker).
OK - now for this next much smaller swing of reproduced drum sound, the amp has to use almost the same amount of power (think 180 W) it had used to push the woofer in the 1st place, to stop it from moving now, plus some extra amount of power to correctly form the next wave-part.
So for real, the amp can at worst only deliver 1/2 of it’s nominal power into a speaker to produce music.
The other half is needed to eliminate the energy from former music events stored in the speaker.
This is specially true for most class-D amps, as they don’t have too high current capability margin, maybe just 50% extra.
They might run of of steam (current) earlier than their specs might suggest when driving a real speaker, not just an artificial resistive load used for the specs measurement.
On the other hand some designers like Mark Levinson built amps that have ten or twenty times the (steam) current capability they would need for their nominal power - these don‘t have problems being driven almost full scale.
To make the life of an amp even harder, the behavior of a speaker is “complex“, which just means the voltage and the current are not synchronous.
A lot lot of amps struggle if this a-synchronicity (phase angle) is too big, because their control mechanism, called NFB - negative-feed-back, has a limited capability to handle this.
This capability is called “phase margin” and typically ends at +/– 180° the latest - voltage and current full anti-phase.
If you now force an amp into it‘s power or current limit on such a complex load, it will completely loose control on the speaker, resulting in momentary very nasty distortions.
If all this sounds bad and problematic to you, don’t worry:
Practically, with a 400 W amp, your neighborhood’s tolerance to sound might be the real world limit - usually somewhere in the 1-figure watts region, which every amp can handle easily.
All clear now wink?
68 (edited by markoveter 2024-06-30 07:41:55)
So this could be true with my Class D amp-speakers combination?
Audiophonics HPAS400ET:
Purifi 1ET400A modules based amplifier with HYPEX SMPS1200A400 power supply.
2x400W@4Ohm
2x200W@8Ohm
My speakers are 87dB and 8 Ohm but stay  most of the time at 6Ohm with 3Ohm peaks
The Purifi datasheet page 20 explains how the amp‘s overload protection works, it’s controller-based.
https://purifi-audio.com/document/share … 4e1501ab94
Reading through it I‘d say it‘s better to avoid this state, it‘s beyond “analog“ clipping.
As the amp‘s short term peak current capability is ca. 20-25 A, this shouldn’t be a problem.
Last Changes:
v5- Added column with Peak values; Vp = Veff RMS value * sqrt(2)
Just bought an ADI-2 DAC FS in the US from an official dealer and found out that it is a B model with the SD-LD filter. So, it seems that there still are AK4493 models floating around in some stock inventories.
The sound produced by this device is truly outstanding, but I don't know if there is an objective reason the send it back. Are there any must have firmware tweaks only available in the ESS version, any changes in the circuitry beyond the ADC chip? Any ideas from forum members?
I am just upset that the dealer did not inform me. I paid full 2025 end user price. Not very nice!
72 (edited by ramses 2025-03-06 14:51:54)
Hi commk, welcome to the RME user forum.
There is nothing wrong with the device.
I recommend performing a full reset and flashing the latest firmware.
Manual
Ch 14.1.3, 17.2:  the AKM converter support DSD direct, the ESS converter not
Ch 14.1.5: ESS units have some ESS specific settings in an “expert menu”
Congrats, you are now proud owner of ADI-2 DAC FS with AKM chip :-)
I would keep it but would try to ask for a little discount if it looks like B-Ware.
For recording stuff at single speed use default A/D filter to have linear frequency response esp at single speed in the audible area up to 20 kHz.
For listening try the Slow filter, see KaiS comments on that.
See the reference links that I put together here: https://forum.rme-audio.de/viewtopic.ph … 03#p233903
Tastes are different, use what you prefer.
73 (edited by KaiS 2025-03-07 06:34:54)
commk wrote:
… it seems that there still are AK4493 models
Absolutely no reason to be upset.
In contrary, the AKM version is sought for by fans of this chip.
I did a comprehensive half-day, level matched blind A/B shoot out between AKM and ESS versions.
With the default “Sharp” filter active on both I could not detect any audible difference.
It ended 49 to 51 for the question “which one sounds better”.
All other selectable DA-filters, even the same named, do sound different.
So, in fact, both chips are a little bit different in this case.
Still, I could not name one chip that is better than the other, I do like both, it might be a matter of taste.
The filters only effect the sound at 44.1 and 48 kHz sample rate.
With everything above they are way out of the audio band.
Regarding firmware:
It’s absolutely recommended to use the latest, there are only advantages.
Thank you both KaiS and ramses for your useful comments. I will follow your advice.
In the meantime I realized that the dealer has probably no way to know what version of the DAC is in the box. The SN label with the B in the lower right corner is only affixed on the unit. On the box outside, only the SN is shown, without the B. The box came wrapped in the original and intact shrink foil, so no tampering there.
In any case, I am more than happy with the outstanding performance of the unit. It was a bit of a shot in the dark, since I have no way to listen to any product before buying. I discovered this RME product only recently and after reading a lot of comments about it on the web (including ASR...), I decided to take the plunge.
It produces most excellent sound out of the box and way beyond my expectations. Cleanliness, faithfulness of the timbre, detail, sound stage presentation, neutrality, everything is impeccable and absolutely first rate. I am a fervent listener of classical music, so all these things are very important to me.
Thank you RME! Great job!
75 (edited by bejoro 2025-03-07 16:52:11)
After many years from the first ADI-2 PRO model to the latest ADI-2 PRO FS R BE (AKM, sonically identical to your ADI-2 DAC) and intensive comparisons of the different filters especially for classical music I would recommend to stick with the default filter SD SHARP at first for a while. Just get used to the new clear and neutral sound of your new ADI-2 DAC FS and enjoy - a fantastic music machine.
After a while (maybe weeks) you can try the SLOW and SD SLOW filters and listen to your favorite recordings again. If you notice some kind of a bit harshness or "squeakyness" (e. g. Strings, Cymbals, Glockenspiel, Flutes, symphonic productions etc.) then try the SD SHARP again and compare.
The differences between the filters are not night and day and rather subtle. It might be the case that SD SLOW or SLOW are better for critical listening or for absolute perfect recordings if there is something like that anyway. In my experience SD SHARP is more forgiving (casual listening) and has a bit better depth gradation than SLOW/SD SLOW. Some sound events jump out of the virtual image with SLOW/SD SLOW and appear suddenly closer than with SD SHARP.
And I prefer SD SLOW over SLOW but mostly SD SHARP.
KaiS is a very experienced recording engineer with his own studio for decades. He definitely knows what he is talking about and a very appreciated member of this forum. But regarding the filters and classical music I am not 100% of his opinion, but that's fine (I hope smile )
Thank you for your comments "bejoro".
At this moment I am enjoying a new journey through my extensive music collection and I can only make one comment: absolutely stunning. My judgement on some recordings is totally upended.
I will try other settings at a later time.
In the meantime, I got in touch with the RME dealer and it appears that they received the unit recently. So, it seems that there is still AKM stock at RME somewhere for those who are interested.
I will keep my unit.
JP
77 (edited by suitofswords 2025-03-10 20:52:27)
I see that the static table in the original post is v7, 08/2024. The “Release Date” years range from 2016-2021. Does this mean that there have been no further revisions to these nine ADI-2 products aside from firmware updates?
And, how do I know the manufacture date of a particular ADI-2 item? I just got the ADI-2 Pro FS R BE new from Sweetwater and I’m wondering how old it could be and if that actually means anything. I see the SN on the back. I’m aware that it would mean nothing if the answer to my question above is “yes”.
Thanks.
In the MADIface driver README you can see different HW revisions.
I am not aware of any new versions.
ADI-2 Pro FS R BE always had AK converters. Simply go for it.
Hi yes I see the hardware revisions; however this connects firmware updates to a hardware revision (e.g. Hw Rev 7). I'm trying to connect my serial number to a hardware revision (or manufacture date as I put it).
I know it's AK. Not a huge deal. I typically document every detail of each piece of gear I have. If there is no serial number lookup so be it. Didn't find anything searching this forum.
80 (edited by ramses 2025-03-10 22:44:50)
If you have an ADI-2 Pro FS R BE, then you have the latest product of this product line. No serial number comparison needed.
Checked RME USA and Sweetwater web sites for adi Pro model. Not listed for sale, only older adi-2 model.  New models coming?
WY
CD Transport>optical>RME ADI-2 DAC FS(AKM)>XLR balanced >GLM software>Genelec Monitors 8340A
Hard to say, probably new models are to come. The current Pro models are marked "end of sale" at our local country distributor.
From that I would guess they are not produced any more and either new revisions of them will come or completely new models.
