1 (edited by ramses 2025-12-14 12:34:21)
Topic: HDSPe MADI FX, 1000 Tracks, 2001 VSTs, 44.1 kHz, Bufsz 128, RTL 6.76ms
Just had a look at the performance of the new setup this evening. Result: HDSPe MADI FX delivers excellent performance.
Artificial Test Project: Simple Playback without Audio Loss with 1000 Tracks and 2001 VSTs.
All 1000 tracks routing into the stereo sum.
RME HDSPe MADI FX, MADI FX driver 2.27 - Samplerate: 44.1 kHz - ASIO Buffer size: 128 samples, RTL: 6.76ms (M-1620 Pro).
I do not remember exactly, but up to around 500 tracks were possible with 32 samples buffersize (1001 VSTs)
and around 700 tracks with 64 samples buffersize (1401 VSTs).
2 VSTs per track: 1. Frequency (preset: Master Bus Mix) and 2. Compressor (preset: Light Master)
Brickwall Limiter in the Stereo Sum.
CPU: Intel Xeon E5-1680 v4 (from 04/2016); multithread performance: 14216 Passmark (single thread: 2310) (*)
Mainboard: Supermicro X10SRi-F (from 2014); 64 GB ECC RAM (*)
Windows 10 Pro
DAW Nuendo 14.0.41
CPU Load: around 64%, DRAM: 42 GB
A few applications were running in the background. Internet browsing with Firefox is possible without audio loss.
https://www.dropbox.com/scl/fi/sayk67k3 … s&dl=1
https://www.dropbox.com/scl/fi/sayk67k3dknofnarym3fa/2025-12-11-Nuendo-14.0.41-1000-Tracks-2001-VSTs-44.1-kHz-ASIO-BUFSZ-128-CPU-64-42-GB-DRAM-1000xFrequency-1000xCompressor-1xBrickwall-Limiter.jpg?rlkey=i37zf6c02kh1qp7zqnf0q9x2s&st=m14u248s&dl=1
Setup: https://www.tonstudio-forum.de/blog/ent … tup-en-de/
(*) Quite nice performance for a HW that has been declared to be not Windows 11 compliant by Microsoft. I won't throw it into the bin ...
Re: HDSPe MADI FX, 1000 Tracks, 2001 VSTs, 44.1 kHz, Bufsz 128, RTL 6.76ms
The HDSPe MADI FX is fantastic! Thanks for this Ramses.
Windows 11 / Nuendo 14 / HDSPe MADI FX / M-1610 Pro / ADI-2 Pro FS R
You're welcome, Robin.
As I knew that you ordered this card, I wanted to give you and other people the opportunity to compare and to see what performance and RTL can be expected from this card in combination with the M-1620 Pro [D].
It also demonstrates, that even a quite dated system can still deliver an excellent performance if everything is fine (DPC latencies, driver, good balance between multi- and single-thread performance.
