201
Re: TotalMix FX 2.0 – first beta available for Windows (now released)
Beta 12 is now available for download and adresses lots of feedback in this (and the Mac) thread:
- Improved graphics compatibility: now works with Parallels (error 102)
- Improved error description: graphics compatibility might not fail due to DirectX 12, but Direct3D 12. Specific error message added.
- Various small graphics improvements
- Added Fullscreen on/off via F11
- Added Ctrl-Z for Undo and Ctrl-Y for Redo
- Fixed ARC USB DURec Play Previous/Next commands were swapped
- Open/close state of Recorder panel is now saved
- Split position in 2 Row mode is now restored
- RoomEQ: after changes on a loaded Preset the name starts flashing
- Pan in C state: double-click opens a dialog to change the numerical value
- Now compatible to ARM (Snapdragon)
- DURec: changes to the Record/Play settings do not cause flashing of the Snapshot button. This is a temporary fix, there will be a save option later for these.
- Options Ctrl-X and Ctrl-M have been added to the Functions menu (to pull them from the shadows. They are not new).
Vertical and horizontal scrolling reworked:
- Horizontal and vertical scrolling has been improved a lot in speed and acceleration
- Horizontal scrolling of rows can be done directly with mice that have a dedicated vertical scrollwheel or a multi-axis single scrollwheel. Also the two finger gesture on a touchpad will work directly for horizontal scrolling.
- Vertical scrolling of all rows (window content) is done via Ctrl-Shift-mousewheel, or Ctrl-Shift 2-finger gesture on touchpad. Note: The 2 finger gesture alone is already used to move faders, so this feature needs the modifiers.
Download in first link!
kr0mka wrote:
Also, the current behavior of labels for RoomEQ is lacking for my use case, i often load a preset and then slightly tweak it (i tend to leave spare filters to adjust during playback) and currently the name persists only when i save/load a preset, when any slightest adjustment is made, the name is lost
What you want requires extremely complicated and extensive 'change surveillance' routines, that are not possible for this current release. They might be added at a later time. The current  (limited) way of working is the best compromise we can offer to have this feature right now.
In beta 12 we improved the 'compromise' a bit by showing an edited state of the REQ preset (by flashing), so the base of the current settings is still revealed.
Awesome! This is enough for me, mainly wanted to not lose the last applied name upon any edit. Works great now, thanks!
Any chance to also implement something similar for the 3 band EQs? Maybe not blinking as that could be distracting, since the 3 band eq is directly on the main TMFX view.
here to report a little graphic bug :
When you use the "gain" button in the dynamics section, it draws a red line on the right of the graphic visualisation, which can be removed only by closing the section, and it mays need many retries to clear it.
Thanks for the software !
I've noticed that Snapshot logic causes volume spikes.
Environment:
- Windows 11
- UCX II (drv 1.276, SW 36)
- TotalMix FX 2.0 beta 12
Issue:
- Snapshot function applies gain‑increasing parameters (fader, EQ, dynamics, input sensitivity) before gain‑reducing ones.
- Results in brief but extreme volume spikes at full gain in certain scenarios.
Steps to Reproduce (as shown in the attached YouTube video):
  1. In Preferences [Snapshots and Workspaces] → [Do not load] = [--].
  2. Feed a test signal (square wave recommended, as it most clearly exposes the issue) to Software Playback Analog 1/2.
  3. Set Snap 1 and Snap 2 (identical except for fader levels: one set to 0 dB, the other to e.g. –50 dB on Software Playback Analog 1/2 and the Main output, and vice versa for the second snapshot).
  4. Switch between snapshots.
  5. Observe momentary overload and audible volume spikes.
Evidence:
- Video: https://youtu.be/UQfkpOr1JAo
Expected Behavior:
- Gain‑reducing parameters should be applied first, followed by gain‑increasing ones.
Fireface UCX II
Thanks to the entire RME team for their attention and effort.
All the best
UCX II FW106/36/104 v1.276 TM2.03 - PC Win11 25H2
I've noticed a weird behavior on the newest beta 12 - not sure the exact cause yet but it happened twice so far, sometimes when I boot up the PC i get no sound through the USB in to the UCXII, the USB icon on the interface is lit up. Also when this occurs the tmfx 2.0 no longer opens, when i run the exe, I see the icon show up in the taskbar and then quickly disappear, then the process dies (no error popup). To fix this, I have to open the old 1.99 TMFX, the sound comes back (I'm not touching any sliders), I close it and then open TMFX2.0, it starts working again as well.
here's the event viewer crash log:
Faulting application name: TotalMixFX_x64.exe, version: 0.2.0.0, time stamp: 0x692831fa
Faulting module name: amdxc64.dll, version: 32.0.22029.1019, time stamp: 0x690ceb3e
Exception code: 0xc0000005
Fault offset: 0x0000000000448dd4
Faulting process id: 0x17D0
Faulting application start time: 0x1DC6425B62D212E
Faulting application path: C:\Program Files\RME\Fireface\TotalMixFX_x64.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\u0421109.inf_amd64_fb479f779d3886ae\B420961\amdxc64.dll
Report Id: 90e155ab-6fa1-4e22-9aff-210abb0519b1
Faulting package full name:
Faulting package-relative application ID:
And crashdump details:
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_NAME:  amdxc64+448dd4
MODULE_NAME: amdxc64
IMAGE_NAME:  amdxc64.dll
FAILURE_BUCKET_ID:  INVALID_POINTER_READ_c0000005_amdxc64.dll!Unknown
OS_VERSION:  10.0.26100.1
BUILDLAB_STR:  ge_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
IMAGE_VERSION:  32.0.22029.1019
FAILURE_ID_HASH:  {79fa917f-acce-2436-f35e-92d487d97f5f}
Followup:     MachineOwner
You are on AMD?
www.dekkermastering.com
yes, 9070xt
210 (edited by Thermaltake 2025-12-05 06:59:31)
Kind of same thing happend to me few days ago, but I am still on beta 11. I was watching some movie in vlc player, and all of the sudden no sound on pc at all. I restart PC and everything was ok after that. It happend only twice now in week or so, so I couldn't figure out what was the cause.
I am on Intel 14th gen.
211 (edited by Kubrak 2025-12-05 15:14:15)
From your crashlog it seems to be a problem in amdxc64.dll, which is library/driver for AMD GPU. It might be caused by TM (some kind of wrongly defined request call to GPU), or by other things....
Maybe TM calls it too soon at computer startup and GPU is not yet fully prepared, or whatever.... Maybe reinstalling GPU drivers would help.
And if that happened and you have tried to run TM 2 again, have you terminated running TM in Process Manager (or what is the English name for....), the tab Processes (rightclick on item in list and choose Terminate ). Otherwise, if it runs (even invisible) one cannot run another instance of TM to replace it...
Yes, I'm aware, this is likely related to the TMFX 2.0 direct3d 12 implementation clashing in some way with AMD drivers.
As I said in my comment, the process dies. There's no TMFX exe visible in task manager. When I try to run it myself, I see it pop up for a moment and the process dies again unless I go and fix it by running tmfx 1.99 first, closing it completely and running 2.0 again.
It doesn't happen on every boot up, yesterday it happened for the 3rd time, today it hasn't, I usually keep my PC on for the whole day.
213 (edited by Thermaltake 2025-12-05 22:17:47)
It happend to me while watching a movie in vlc player I was watching for 45min. and all of the sudden no sound. But only two times in few weeks, so I didn't make any deal of it. But now since others are reporting similar problem I am reporting it too.
Bug Report: Fader Group Behavior in TotalMix FX Beta 12
Description: When switching between snapshots that involve stereo-to-mono channel changes, Fader Groups incorrectly expand to include unintended channels.
Steps to Reproduce (YT video https://youtu.be/rHafu_KL6lA):
  1. Save Snapshot 1 with channels 1 and 2 configured as Stereo.
  2. Modify configuration: switch channel 2 from Stereo to Mono.
  3. Create Fader Group 1 linking faders of channel 1 and channel 2.
  4. Save Snapshot 2 with this configuration.
  5. Switch back to Snapshot 1, then again to Snapshot 2.
  6. Observe that Fader Group 1 now links three faders (channel 1 stereo, channel 2 mono, channel 3 mono) instead of the expected two faders (channel 1 stereo, channel 2 mono).
Expected Behavior: Fader Group 1 should consistently link only the two defined faders (channel 1 stereo and channel 2 mono) across snapshots.
Actual Behavior: After switching snapshots, Fader Group 1 incorrectly includes an additional fader (channel 3 mono).
Impact: This behavior causes unintended grouping and control inconsistencies, making snapshot recall unreliable in configurations involving stereo-to-mono changes.
Environment:
Windows 11 25H2
Fireface UCX II
215
I really like the updated look and that it can be resized and zoomed.
But I'm really having issues with the overall extremely low contrast even on high contrast.
High contrast should not only slightly dim the background compared to dark. It should also increase the text brightness.
FireFace UFX III + OctaMic XTC @ MADI + FireFace UFX @ ADAT
216 (edited by d3bil0x 2025-12-08 01:44:24)
Bug Report: TotalMix FX 2.0 beta 12 – crash on startup with specific screen resolution parameters in config file.
Issue Description: The TotalMix crashes immediately upon startup when specific configuration values are present in the file last.FirefaceUCXII1.xml. This file is generated automatically by the application during a previous normal shutdown.
Steps to Reproduce:
  • Completely exit the application (not just close the window) so that it generates last.FirefaceUCXII1.xml.
  • Ensure the configuration file contains the following values:
<Frame0>
    <Window>
        <val e="WinPos.left" v="0"/>
        <val e="WinPos.top" v="0"/>
        <val e="WinPos.right" v="2560"/>
        <val e="WinPos.bottom" v="1600"/>
        <val e="ScaleType" v="2"/>
        <val e="IsMaximized" v="0"/>
        <val e="IsFullScreen" v="1"/>
        <val e="FuncType" v="0"/>
    </Window>
</Frame0>
  • Launch the application.
  • The program hangs and then closes immediately.
Condition Triggering the Bug:
((WinPos.right - WinPos.left == 2560) &&
        (WinPos.bottom - WinPos.top == 1600) &&
        (IsFullScreen == 1))
If either the window width or height values differ from 2560 or 1600, the application does not crash.
DMP Analysis (safe extract):
Dump File: TotalMixFX_x64.exe.24036.dmp
Exception Address: TotalMixFX_x64+0x12edce
Exception Code: c0000005 (Access violation)
Details: Attempt to read from address 0000000000000000 (null pointer dereference).
Faulting Module: ntdll
Stack Trace (trimmed):
TotalMixFX_x64+0x12edce → crash point
Subsequent calls within TotalMixFX_x64 leading to user32!CallWindowProcW
Ends at kernel32!BaseThreadInitThunk → ntdll!RtlUserThreadStart
Environment:
Windows 11 25H2
UCX II (drv 1.276, SW 36) / TotalMix FX 2.0 beta 12
CPU/iGPU Ryzen 9 7950x (drv 25.10.33.03-251106a-420894C-AMD-Software-Adrenalin-Edition)
dGPU RTX2060 12GB VRAM (drv 591.44 studio)
4 screens: 2560x1600, 2 x 1920x1200, 1920x1080
96GB RAM
Fireface UCX II
After a GPU driver update (Nvidia), TotalMix 2 beta 12 crashes when opened from the system tray icon. After restarting TM, it works again.
d3bil0x wrote:
I think this is the issue. I had the problem happen today again and for me it's directly tied to whether I have TotalMixFX in fullscreen mode when I shutdown the PC.
I looked up the window settings in the last.FirefaceUCXII1.xml when TMFX was unable to open and this is how it looked like.
https://i.ibb.co/fYT27QKr/image.png
After changing the fullscreen variable to 0 and retrying to launch it worked. Then I set TMFX up like I always have, on my 3rd monitor in fullscreen, then closed TMFX through tray. This is how it looked after reopening the xml:
https://i.ibb.co/DHP3dJrG/image.png
What I think might be happening is a monitor layout mismatch vs the last.xxx.xml config, my pc has 3 screens and i cycle between two display output configs, outputting to my main screen + totalmix screen for the first half of the day and 3 screens total for the rest of the day. Not sure where the issue occurs exactly though as I don't change the layout of the screens when totalmixfx isn't running. Might be related to when totalmix actually updates that xml file?
219
Next beta with fix for this problem is on the way...
Just an FYI, seems having Gsync on causes flickers when TM is open AND selected with the mouse, if I select another window the flickering stops, this all goes away when I turn Gsync off.
Running Beta 12 and W11 Pro....Loving the high contrast look, please do some more skins RME!
221
Beta 13 is now available, see link in first post.
List of changes:
- Fixed full screen bug as reported in this thread
- New option 'Reduce volume peaks on Snapshot load' to better handle exterme gain/volume changes between Snapshots, preventing short loud noise bursts. This new feature is ON by default, but can be disabled in Options/Preferences.
- New option 'Load Groups with Snapshot', aka Fader, Mute and Solo groups. This option allows a more flexible control as the groups are no longer bound to Workspaces alone.
- New option 'Record/Play with Snapshot'. This option allows a more flexible control as Record/Play settings are no longer bound to Workspaces alone.
- Several small improvements
Cosmetic issue (in beta 13):
When right‑clicking on a Channel in the Hardware Inputs and selecting Change Channel Layout, the Channel Layout window does not automatically switch to the Inputs Tab. Instead, it displays the last used tab and requires an additional click on Inputs Tab if Playbacks or Outputs Tab was previously active. In comparison, for Software Playback and Hardware Outputs, the correct tab is activated automatically.
Fireface UCX II
223
Good hint!
Oh wow, what?  You guys implemented my suggestion for a fullscreen shortcut??
ICH LIEBE EUCH!!!  Vielen, vielen dank!
Adjusting the headphone fader with the mouse wheel feels more accelerating than before.
If move the mouse wheel suddenly, the volume also changes suddenly.
I feel like it was more gradual before.
Sorry if I'm mistaken.
Thanks for updating the most stable and reliable drivers/software in the industry. Can't wait to try it when is officially released.
Excellent update!
Hey guys,
I noticed that in the new Totalmix 2.0 (Beta 13) the Fine mode modifier for the faders doesn't work (Shift Key + Scroll or Mouse Drag).
If I switch back to the old design it still work as expected!
229
Shift key plus scroll wheel still works in the new design. Shift plus mouse drag will hopefully be added later.
Any chance improved Mono/Stereo channel handling will make it into the TMFX 2.0 development???
https://forum.rme-audio.de/viewtopic.ph … 90&p=3
231 (edited by d3bil0x 2025-12-21 18:11:27)
TotalMix FX 2.0 Beta 13. When recalling a Snapshot that contains a saved Group, the corresponding Group does not always appear as active in the Groups window, as shown in the attached video: https://youtu.be/-fofi7DEP1k
Fireface UCX II
Love the new look!
But what about changing the window decoration to match the dark mode on Windows 10 when that is enabled? It's currently bright white and it doesn't really match the new aesthetic.
The Mac OS screenshot looks much more pleasing.
Anyway, really appreciate the resizable UI and the new loudness meters. Great stuff!
Gain knob label in config tab is displayed in "db" instead of "dB"
https://i.ibb.co/zh6cjtRF/db-jpg.png
Intel i7-9700, Asus B365M-A, Win10, UFX+, ADI-2 Pro FS R BE, ADI-2 FS, Ferrofish Pulse16 MX
234
Nice one!
235 (edited by sighs_14 2026-01-03 02:56:03)
Horrible crash on Windows with beta 13. Just now, Nuendo froze completely (but kept playing) I have already deleted and re-installed the app last week. When I restarted, I got a popup from TMFX "Returned 887A0005 at 10" I've had a few of those lately. That's why I tried re-installing the app. Should I remove or change the drivers? Thanks for any suggestions.
Windows 24H2/Fireface 802/Octamic II/Firewire. Totalmix FX Beta 13/ Driver 1.0.30.15 x64
236 (edited by d3bil0x 2026-01-02 16:08:07)
Bug Report in TotalMix FX 2.0 Beta 13
Issue: GUI malfunction in Room EQ window.
Description: After opening the Room EQ window, minimizing the main TotalMix window (either via standard minimize or using Windows + D) and then restoring it, the Room EQ GUI stops visually updating when adjusting parameters. The parameter values do change internally, but the interface does not reflect them. Closing and reopening the Room EQ window restores normal visual behavior and shows all previously applied changes.
Steps to reproduce (as shown in the attached video https://youtu.be/VF1QBHxKv7s ):
  • Open Room EQ window.
  • Minimize the main TotalMix window (regular minimize or Windows + D).
  • Restore the main window.
  • Adjust any Room EQ parameter.
Environment:
Windows 11 25H2
UCX II (drv 1.276, SW 36) / TotalMix FX 2.0 beta 13
CPU/iGPU Ryzen 9 7950x (drv Adrenalin 25.12.1)
96GB RAM
Fireface UCX II
237
Confirmed, thanks!
I'd like to also report that the RoomEQ window has something wrong with scaling, every time I open RoomEQ it spawns a window that spans over my 3 screens instead of scaling to the monitor im currently using totalmix on. Resizing it works, but when I close RoomEQ and then reopen it, it goes very big again.
Here's a pic of how it looks on every RoomEQ open: https://i.ibb.co/bgp9k67z/roomeq.png
Basically, it is the case that quite a few windows of the TotalMix FX program will not open in the middle of the window, but rather arbitrarily somewhere at the edges. For example, the 'Settings-window' etc. When operating with several monitors (screens), the window chaos seems to become even bigger. For example, with the Room-EQ window. I have already addressed this circumstance here in this thread. I really hope that future TotalMix FX versions will basically open the other dialogs in the middle of the window and remember the state of position.
Fireface UFX II - Babyface - HDSPe AIO - Multiface
241
Oops! big_smile
Here comes beta 14, addressing various feedback (aka bugs and issues) from this and the other thread. Download links in first post - Check it out!
- gain labeled dB
- Room EQ windows are now cached with size and scale information
- Window sizes are now correctly adapted when changing between monitors with different DPI settings
- In Classic design REQ windows were wrongly positioned as well – fixed
- Minimizing the app the REQ windows were not minimized simultaneously – fixed for both taskbar and tray icon
- Nearly all dialogs will now be opened in the middle or above/below the respective element, reducing mouse travel
- Fixed wrong menu entries for Fireface 802
- Menu entry ‘Store current state into device’ was disabled
- Undefined title bars of windows are now set to black (menues unaffected)
- Removed several write processes during shutdown that were no longer needed
- Re-added the Load and Save buttons in the ARC Settings dialog
- Loading Snapshots with Groups (Mute, Solo, Fader) after Snapshots without Groups could cause Groups to not load
'nuff said!
Thank you, Matthias!
Windows 11 / Nuendo 14 / HDSPe MADI FX / M-1610 Pro / ADI-2 Pro FS R
244 (edited by Vlad Vilnev 2026-01-15 09:30:32)
Well done! Thanks !
- gain labeled dB
'nuff said!
Because of this, the window has now turned black? But the menu is still in light mode, which seems a bit conflicting (my computer theme is also light mode). I think this is a good idea, but it would be better to have an option (dark/light/follow system) and keep the colors of the title bar and menus consistent.
246 (edited by ramses 2026-01-15 15:23:13)
+1 fully agree; a black title bar doesn't look good.
I also think the readability of the right side of TM FX  still needs to be improved.
For example, titles of sections like "View Options", "Snapshots", "Groups", "Layout Presets", ..
For the font, I would use a brighter "white" to give it more contrast and I would use capital letters again
at the beginning of words to increase visibility/separation of the different areas.
247
A +1 for the follow system settings mode for colour scheme. Also use of capital letters for the beginning of words
Agreed, also since yesterday (and this might be because of this weeks w11 security update) I can no longer execute a shortcut from taskbar or desktop, as windows now says this is a potentieel malicious internet shortcut. The tray icon, or executing from the program files / rme folder works fine. But a shortcut from tmfx in that folder doesn’t?
249 (edited by Thermaltake 2026-01-16 18:31:58)
There is a bug in about window, year is still 2025 big_smile I'm just kidding, everything is looking good for now, gonna test it these days.
250
MS Defender out of control - again...I bet...
