Topic: Tiny Control Strip section
Hi guys,
I just installed TMFX 2.01 on my Mac Studio and whatever I try to do, the Control Strip section of the TMFX window is really tiny, impossible to see or operate. All the rest of the sections scale properly when I enlarge the window, but the control strip just stays tiny.
I have 3 monitors on this Mac, two are 2k and one is 5 k, but the same behaviour applies to all of them.
Can anyone advise?
I'll post a link to a screenshot below.
Thank you
https://www.dropbox.com/scl/fi/joie1rmx … h&dl=0
2 (edited by Kubrak 2026-05-04 21:58:45)
Re: Tiny Control Strip section
I am not on Mac, but I guess this is right for Mac. You have to use Command key + mouse wheel to adjust size of Control Stripe.
EDIT.
In Win it is Ctrl+mouse wheel.
Thank you so much, command+wheel does the trick!
I can reproduce this if I switch Window/Set Scale to 50 % and then manually increase the whole window, then this section does not seem to follow. Increase the scale setting.
Or use the other method to scale it...
