Topic: Feature Request: Pan Meter
A pan meter similar to what WaveLab currently has would be highly appreciated.
The following link is screenshot from Wavelab,
The following description is from Wavelabs own manual,
Pan Meters
The lower part of the window shows the difference in level between the left and right channel of a stereo audio file.
The upper pan meters show the peak level difference between the channels. The level bars can go to the left or right, indicating which channel is loudest.
The lower pan meters show the average difference in loudness between the channels. This gives you a visual indication of whether a stereo recording is properly centered, for example.
If you are monitoring real-time audio (playback or input), the maximum balance difference values (peak and loudness) for each channel are displayed numerically to the left and right of the meter bars.
Thank you
