Topic: UFX+ blue blinking host LED with USB3 sharing switch
I have a setup where I need to intermittently use a Fireface UFX+ (latest FW) on two computers (Windows 11, latest RME drivers).
As both machines are located at different places, a full KVM switch is not required and I got an Ugreen CM662 USB3.0 sharing switch with only the UFX+ (and optionally power supply) connected to it.
But the UFX+ is not recognized by any computer connected to the switch and the host LED is blinking/flashing blue.
Changing cables did not do the trick.
However, when using a USB 2.0 cable, the host LED is steady orange and the device works without required MADI (as expected in USB2 mode).
I first blamed the USB sharing switch, but: a MadifaceXT is working in USB3 mode without any issues. So, I suspect that it is not (only) an issue of the Ugreen USB switch.
Could it be a UFX+ HW issue? Or is is USB3 HW/FW very different between UFX+ and MadifaceXT, giving latter more robustness?
I had some reports about a blinking host LED from other people using the UFX+ (without the switch) once in a while, especially if not directly connected to the host, but via USB hub.
Thank you very much for any hints or information
