MC wrote:I don't get why one would want to have TM FX in the background covered by other windows - what is the advantage compared to the current complete hiding?
Oh, it's simple. If you open the TM FX window, do some things, and then just click another window (which will cover the TM FX), you can't get to the TM FX with the shortcut ARC key, you need to alt-tab (which is slower and less convenient, also it doesn't have to be ONE alt-tab, often you need to find the TM FX in the stack and alt-tab more times). You can of course remember to always close the TM FX, but you don't want it in all scenarios. For example: often TM FX shares another monitor with DAW mixer. You need to do some changes here, some changes there... Tapping ARC key (once or twice) should be the fastest way to get to the TM FX.
waedi wrote:I think OP had experienced a misbehavior mistake by the software on his computer
One of the windows of another software was forced to keep upfront I guess.
Expectation of OP :
Toggle Totalmix windows brings up upfront one or the other Totalmix windows, but it didn't worked.
He thinks the toggle function is not working the right way as he expected.
The function "Toggle Totalmix windows" to use as a trick to flip back and forth between two Mixer windows, instead of using two snapshots...
What?
I use only one totalmix window. The "misbehavior mistake by the software" acts the same regardless of whether the another software is Reaper or Chrome. It might be the misbehavior of Windows or some 3rd party app, but it looks like misbehavior of Totalmix.
Kubrak wrote:I guess, it is very questonable, whot should happen in this very case.
IMHO, the standard Win behaviour is, that if App is not upfront and something changes in that App, it does not bring it upfront. It stays below/behind upfront Apps.
What OP could do is to close TM instead of covering it by other Apps. Maybe that toggle made by ARC would open TM and bring it upfront. One would have to try.
I made a video about the issue: https://www.youtube.com/watch?v=Gf5U0iYUoyo
The Totalmix FX:
1. tries to go to the foreground but it can't and stays in background
2. sometimes shows like it is the active application (with the title in black color), but it's still not the active application
3. sometimes isn't the active application even after opening it from the traybar (so you open the totalmix and pressing F3 does nothing instead of going to settings).
4. Why one would want to toggle the visibility of a window which is not visible because it is behind 3 other windows?
Kubrak wrote:NOTE.
I guess, RME could implement what OP suggests, but maybe that users with different workflows/habits would mind it, because they are acustomed to current state...
If ANYBODY loves their habit of pressing alt+(shift+)tab to find the Totalmix window somewhere in the window stack (I really can't think of an example when it is useful), RME still can leave the option "toggle totalmix window" and just add the option "toggle totalmix window and bring it upfront"
. But I'm sure it's a bug (or a misbehavior mistake on my Windows) as the Totalmix window taskbar button starts to blink.
