Topic: INT clock / SRC - no SPDIF signal
It could be that I've misunderstood whether this is possible, but I'm running into an issue where SPDIF input has no signal when SRC is enabled and clock is set to INT. I think Section 27.2 describes this setup for running multiple clock masters, so from what it seems, my configuration is correct.
My setup:
- ADI-2/4 Pro SE, DSP 40
- USB connected, CC-Mode: 6/8 multichannel
- SPDIF In: Optical
- Clock Source: INT (192 kHz)
- SRC: SPDIF In
- SRC Gain dig.: 0 dB
State Overview shows:
- SP op: lock, 48 kHz, cons, 16-bit
- USB: conn, 192 kHz, 6/8
- SRC: SPDIF
- Clock Source: INT
The SPDIF column on the level meter screen shows no signal at all (this occurs whether INT clock is set to 192, 96, or 48 kHz). If I set Clock to SPDIF and turn SRC off, the SPDIF input works, signal appears and audio passes through normally.
Is there something I'm missing?
Re: INT clock / SRC - no SPDIF signal
What exactly is connected to the input?
Odd, I just went back to adjust the settings again to confirm that the signal worked fine when setting the Clock Source to Auto; then after moving it back to INT, it's now working!
State Overview now shows:
- SP op: lock, 48 kHz, cons, 24-bit
- SRC: SPDIF
- Clock Source: INT
Not sure why it's suddenly different, but it seemed me stepping away for a bit must have helped. For posterity I've a Samsung TV connected to it.
4 (edited by waedi 2026-06-08 21:48:20)
Samsung TV has a fix sample rate 48kHz, it can't sync to other devices, right ?
Your setting clock source should be external (Samsung TV) or auto
Appreciate the post, but my configuration is now working as I had hoped.
48kHz is indeed what it seems fixed to, though with the SRC feature, it should be able to convert that up to a 1:7 rate (Section 8.6).
do you expect a benefit from this upsampling ?
