1 (edited by Potscrubber 2025-10-08 03:50:05)
Topic: Nix - displays/shortcuts widget for TotalMix FX Windows (Intel x64)
Hello fellow RME fans
Just a small promotion here for a widget I've developed to work with TotalMix FX, for Windows OS only (sorry).  It provides an on-screen display of the volume level of up to three hardware output channels, mute and volume for those channels, control room functions plus shortcuts, and also a shortcut for the TotalMix FX window.  I see it as an accessory for the ARC USB really, and also the Babyface and MADIface desktop.
Matthias Carstens kindly ok'd me to post about it here on RME's forum.
Price is USD $5.
Demo can be trialed for an hour at a time.  Activation code sent automatically on purchase.  Checkout is handled by SellApp.
cheers!
https://bsound.co.nz/downloads/screenshots/nixosd3-400x300-crop.jpg
Changelog:
Version 2.8.0 - 8 October 2025
- Accomodate TotalMix FX in new install locations such as C:\Program Files\RME\Fireface
- Accomodate TotalMix FX executable in both old and new filenames like TotalMixFX_x64.exe
- Changed nature of elevation alert
Version 2.6.0 - 4 November 2024
- Added outgoing IP address / Host name for working with TotalMix FX over LAN
- Added option to call TotalMix Remote application with shortcut
- Improved level calculation with more accurate formula (thanks RME)
- Updated frameworks
Version 2.5.0 - 20 February 2024
- Added shortcut for Recall (Main out)
- Fixed shortcut label errors
Version 2.4.0 - 5 January 2024
- New option to disable display time-out if Control Room indicators are active (e.g. Mono, Talkback etc)
- Several optimisations and bug fixes
Version 2.3.0 - 27 July 2023
- Short fade out added for Display time-out
- Removed from Windows Alt-Tab task switching
Version 2.2.0 - 19 May 2023
- New shortcuts for toggling pairs of all 3 channel mute states
- Pin to desktop option (replaces and inverts Always on top which is now the default behaviour)
- Click-through (non-interactive) option for all colours
- Optimisations and bug fixes, particularly for handling graphics and OSC
- Less stupid looking pop-ups
Version 2.0.0 beta 4 - 20 February 2023
- Better handling of TotalMix FX window shortcut, especially after boot
- New option Always on top
- New option Lock display position
- New colour options: Maroon, Green, Transparent + click through
- In this mode, Nix can display 1,2 or 3 TotalMix FX channels, their volume and mute status
- Display status of TotalMix FX control room function states: Mono, Dim, FX Mute, Speaker B, Talkback, External Input
- Shift-Click on Nix display to see channel names temporarily
- More Shortcuts for all 3 channel mutes, plus volume up / down for each, and for control room function toggles
- New options for warning of issues with TotalMix FX OSC communications
- New icons, updated user guide
Version 1.2.0 - 17 August 2022
- Bug fixes and improvements
- Demo and registration
- Run as Administrator
Version 1.0.0 - 1 August 2022
Sequoia 17, W10 x64
2 (edited by Potscrubber 2025-01-10 23:39:17)
Re: Nix - displays/shortcuts widget for TotalMix FX Windows (Intel x64)
Just a small update to say there is now a demo for this widget.  You can trial Nix for an hour at a time and test it out in your environment.  Purchasing a license sends an activation code to your email, to fully register Nix.
Cheers.
Sequoia 17, W10 x64
Just amazing, wow!
This together with the Midi functions in TotalMix made my setup super smooth. Thank you!
4 (edited by rpnfan 2023-02-20 09:28:14)
Please pin this thread, because Simon did not get enough attention for this great program and people likely will miss that a solution to display different volume levels, change them via hotkeys and use control room functions exist. I even think that RME should include those solutions in their driver. If not at least they should make those available in the downloads section as well. And if not at the very least they should very clear mention those existing 3rd party options, so that every new user not easily can find the information, but is guided to that information (via handbook, website, forum).
P.S.: In contrast to "Totalmix volume control for Windows" this solution works for me and offers more features, while at the same time being much more lightweight.
5 (edited by BuckleBean 2023-05-04 03:27:10)
Demoed this for a few minutes and purchased a license almost immediately. Being able to include Speaker B is a very welcome addition for my purposes. I appreciated "Totalmix Volume Control," especially being free. But I had frequent disconnects, especially after my PC wakes from sleep. If that happens with Nix, I'm going to assume it may be related to some combination of my Totalmix settings + OSC + Windows going awry.
On another note, I'm very pleased with how Nix handles Volume up and down increments with simple whole numbers. Doing it by percentage got me inconsistent results when pressing the vol up/down buttons. I know it's nitpicky, but if I wanted to quickly recall a specific volume, it was often off by a few decimal points. If I'm A/B-ing something, I want it to be identical.
EDIT: I'd also like to request that this thread be stickied. I think the community would be well served. BTW, no disconnects after my PC waking from sleep, or otherwise. So far so good.
EDIT 2: Over a week later, still no disconnects. As stable as can be.
I am using Nix now for a few months and do not have any problems. Simon did a great job to even catch edge-cases, so I am very confident that Nix is running stable and reliable, which for me "Totalmix Volume Control" wasn't.
Just a note that Nix has had an update.  See OP for more deets but today's release includes:
Sequoia 17, W10 x64
Reporting a small update for Nix.
Sequoia 17, W10 x64
I just see that there have been some updates of Nix. I use it daily and is greatly recommended.
@mod: could this thread be pinned please, because this program is almost a must-have for every TotalMix user on Windows.
Thanks for the bump rpnfan.  I had actually forgotten about this thread as it's so quiet.  Have updated version in the OP.  Cheers!
Sequoia 17, W10 x64
I use it all the time, it is very fast and reliable thanks to OSC.
Georg
12 (edited by Potscrubber 2025-04-03 12:08:32)
Martin2020 wrote:
[Spam deleted]
Seems fine here, never more than 0.4% cpu in Process Explorer.  I took great pains to make Nix as efficient as possible.  But I must admit I haven't tested it on anything prior to Intel 8th gen H cpu.
You can run it for an hour at a time in demo mode to see if it works for you.
Sequoia 17, W10 x64
Leo55 wrote:
[spam deleted]
Hi.  Thanks for supporting Nix.  It was something I hacked together for myself, then some colleagues said I should make it available.  It was a lot of work to make it palatable for others, even though it's "nothing".
Your feedback: could you expand on "custom channels or channel choice"?  Do you mean Hardware Inputs and Software Outputs?  Also, "support for additional devices" ?  As far as I can test with a few RME devices I have, Nix supports TotalMix FX not specific devices.
Cheers
Sequoia 17, W10 x64
Congrats @Potscrubber for Nix. It looks nice! (Being on macOS, I haven't used it myself)
Reading this thread makes me feel there are 4 bot posts. All one-time-posters with a short name and some numbers, super positive review-like comments, a smilie at the end, which by the way contain a link to polish house-renovation websites ...
It hurts seeing helpful community members answering to this AI-produced BS.
Thanks for pointing that out, didn't notice. Indeed all somehow polish accounts, apparently.
Deleting.
Hell!  I totally missed that.  Gotta up my awareness....
Thanks @soundflix
Sequoia 17, W10 x64
17 (edited by Potscrubber 2025-07-25 02:26:13)
I've had a couple of reports that Nix cannot find TotalMix FX in C:\Windows\System32, and a user reported that his TMFX exe is in fact now within Program files\RME\Fireface.
edit: just found the info I need in the RME Downloads section for TotalMixFX.
Will have a new Nix version for users of 64 bit TotalMixFX in the new location shortly.
Sequoia 17, W10 x64
This looks like just what I need! I'm looking forward to the latest fix!
Windows 11 / Nuendo 14 / HDSPe MADI FX / M-1610 Pro / ADI-2 Pro FS R
19 (edited by Potscrubber 2025-10-08 04:33:18)
Version 2.8 is now released, and automatically handles TotalMix FX installed folder locations and executable names both old and new-style.  It took me a while to work out a logic I was happy with that covered all situations (including using TotalMix Remote), with minimal user management required.
Changelog in the OP updated.
Thanks to all the Nix users who support the project!
Sequoia 17, W10 x64
Nix has become a critical part of my workflow here and I couldn't function without it. It is such an elegant and beautifully designed app. Installation was simple. A huge thank you for developing this amazing piece of software!!
For anyone using the ARC remote this is an essential tool - highly, highly recommended.
Works great with new update and TotalMix 2 beta
WIN10 / TT030 – Mackie 24•8, RME 802, MPCX, E-MU E4X, S6000, S-760, 3630, SMP24, MK88, UM880, KRK 7
22 (edited by Potscrubber 2025-10-09 08:08:41)
Just a note for anyone using Nix with TotalMix FX beta 2.x.  Currently the beta arrives called: TotalMixFX.exe
However, recent release downloads that are using the new location of C:\Program Files\RME\Fireface (or Madiface) are using an executable called TotalMixFX_x64.exe
Nix "elects" a TotalMix FX executable - in order to work with old and new installations.  This is how it prioritizes which one to use:
1. Any TotalMix FX that is currently running
2. Any that is set to autostart with Windows (in the RME registry key - details in Nix User Guide)
3. Any in C:\Program Files\RME\<any folder> over C:\Windows\System32
4. Any called TotalMixFX_x64.exe over TotalMixFX.exe.
5. The higher version number (after all of the above).
So if you copy beta 2.x TotalMixFX.exe to C:\Program Files\RME\Fireface alongside the 1.99 TotalMixFX_x64.exe .... then the non beta will "win" the election if no TotalMix is running.
How to get around this with the beta:
Temporary: Manually start TotalMixFX.exe beta 2 (not with the Nix shortcut key).  Optionally run Nix after you start TotalMix FX, but it shouldn't matter.
Permanent: Rename the beta to TotalMixFX_x64.exe, and edit the registry key to autostart that exe with Windows (details in the Nix User Guide).
Accepting any suggestions on changing the election priorities.  Perhaps the version number should be above the executable name and the location.
[edited for proper executable names and clarity]
Sequoia 17, W10 x64
Whoops edit last post as I typed the exe names wrong!
Sequoia 17, W10 x64
Note: Nix is not currently compatible with the new optional Global OSC mode introduced in TotalMix FX 2.1+ in March 2026.
Sequoia 17, W10 x64
can you explain more?  For me the things I set up long time ago are working fine.  Is this something new?
Will there be a new version?
Regards!
26 (edited by Potscrubber 2026-07-08 01:38:30)
Regards!
There is a new alpha version of TotalMix FX available on the forum, where OSC can be switched to a new optional Global mode.  This has been a long term user request and exposes every parameter to OSC in a direct manner.  Up till now, the OSC behavior has been based on an adaption of Mackie MIDI controller commands, with things like banking, and some other quirks.
To support the Global mode, Nix needs a complete re-write of the OSC back-end.
[edited 8 June due to new info]
Sequoia 17, W10 x64
Just an update for Nix users, that v3 development has started, which be a complete revamp of the settings interface, and support OSC global mode for forthcoming TotalMix FX versions.
Sequoia 17, W10 x64
28
Nice to hear!
Great news! I can't live without Nix!
