Topic: Feature request: True peak meter for the ADI-2 Pro (EX) lineup
Hello together,
while I found a few posts regarding this topic including a request by famous mastering guru Bob Katz, I couldn't so in regard to the integrated display of the ADI-2.
Maybe it's already too late for the ADI-2 Pro EX, but for the upcoming flagship ADI-2/4 Pro EX, it would be nice to have a "True Peak Meter" which shows intersample peaks as they occur during upsampling* or the D/A-conversion.
* being the actual method to "discover" then instead of simply using the raw digit values to represent the levels.
I am aware that this is more resource intensive than a non "true peak meter" and one can argue that thanks to RME's additional headroom, this isn't going to matter anyway, but that one might say about the whole level display.
It definitely would be a nice and quite unique "gimmick".
So it would be great to know what @MC's take is on this, whether it's something which could be implemented if there's enough interest, or too demanding given the DSP power.
Thanks and regards
little-endian
2 (edited by KaiS 2026-08-11 00:12:39)
Re: Feature request: True peak meter for the ADI-2 Pro (EX) lineup
You're aware that these "true peaks" caused by intersample peaks do not exist in the digital domain.
They only occur after DA-conversion, in the analog signal.
It's possible to simulate them by some amount, but as even the reconstruction filter's ('DA-filter's) shape has some influence on those, it can only be an estimate.
ADI-2 BTW has an analog headroom of 2.5 dB to deal with ISPs, so their detrimental effect does not occur on the device itself.
My best guess is, as ISPs are omnipresent these days (masters commonly are "smashed to the wall") converter chip manufacturers have taken measures to handle them.
Therefore I think they are of minor interest now.
Some limiter apps can avoid them, but this comes at a cost, lower level and partly other audible side effects.
Thanks for your reply which I especially appreciate due to your tremendous electro-technical knowledge ("jemand, der richtig Ahnung hat"). In order not to overdo the flattery, I'd nonetheless challenge some parts of this response regarding its precision.
No worries, I am. In the original PCM data, by definition, we only have discrete, quantized sample values from a finite set.
However, intersample peaks are not an inherently "analog-only" property. It is a property of the reconstructed waveform, and that waveform can be reconstructed numerically as well as physically.
In other words: if one accepts that intersample peaks may be "introduced" (for a better word than "exist") eventually in the analog domain, one should consequently also consider the introduction of them in the digital domain during calculations such as resamplings as evidently, one can obtain samples exceeding 0 dBFS during digital oversampling/resampling from an original PCM stream whose individual samples all remain below 0 dBFS, without any D/A conversion taking place. Which is how a " 'true' peak meter" gets mathematically implemented. Otherwise one would need a DAC/ADC-loopback chain and appropriate level calibration which probably is rarely performed in practise.
The same principle applies to images or video by the way, where individual nominal pixel values can exceed the range of the original samples as a result of scaling, interpolation or other processing operations.
Due to the former argument, I wouldn't call it a "simulation" (rather "estimation") because from a mathematical perspective, it is as "real" as the generated analog output, but I agree that the calculated peak display will not exactly reflect the actual result. But I'm sure we concur that it would provide substantially more information than a simple 1:1 mapping of the values as we have now. In that sense, it feels odd to me to reject the idea right away to improve the precision of peak display just because it will never entirely match the "real" result.
I know, so the display would rather be "nice/cool" to have as stated in my original post, not an ultimate necessity.
Sure, one can also easily argue that most productions nowadays are so lousy that any intersample clipping which may occur, won't make any significant difference anymore - if it does in general, which is also under quite some debate.
From an engineering perspective, it is always good to have additional headroom or jitter suppression - audible or not.
4 (edited by KaiS 2026-08-14 00:20:28)
Digital signal processing these days is usually done in float formats, or, like within ADI-2, with extended bit resolution above 0 dBFS.
ISPs are handled gracefully this way.
Where ISPS can lead to (digitally) internal clipping is, when the result of a processing is stored in a standard format like straight 16 or 24 bits with no headroom.
Resampling (with no extra measures taken) to another sample rate is a good example for the problematic:
ISPS are turned into real digital peaks above 0 dBFS that can't be stored in the above formats, hence you get digital clipping.
On the other hand, there are a multitude of resample algorithms which all do react differently on ISPS.
My favorite resampler e.g. usually doesn't peak more than 1 dB above input.
So a "true" peak meter implementation into ADI wouldn't be so "true" in this case.
Will RME spend a significant effort to give the people a "guestimate" meter - I doubt.
There's already a lot of requests from people not understanding the red OVR-indicator in ADI-2's peak meter.
