Topic: Currently available interfaces that work in linux
Is there a list of current interfaces which are compatible to linux?
2 (edited by waedi 2026-05-03 09:35:25)
Re: Currently available interfaces that work in linux
Almost all ( in class compliant mode )
Not the hdsp cards
Not the Madiface USB
Pick one interface that looks interesting for you and check the user manual for "class compliant"
In some cases you need a Windows or Mac computer to switch ON CC-mode in the interface, afterwards connect the interface to a Linux computer and use the audio inputs and outputs of the interface directly.
3 (edited by ramses 2026-05-03 10:33:29)
For a list of class-compliant USB 2 and USB 3 interfaces, see my Excel, Overview, line 92:
https://forum.rme-audio.de/viewtopic.php?id=35156
UFX III introduces USB3 Class compliant mode.
UFX III and UFX II are currently available at a good price here in Germany, -22% and -17% off UVP (RRP/MSRP).
https://www.thomann.de/de/rme_fireface_ufx_iii.htm 2326 € (-22% off, UVP 2999 €)
https://www.thomann.de/de/rme_fireface_ufx_ii.htm 1999 € (-17% off, UVP 2399 €)
4 (edited by Hopslost 2026-05-06 17:39:55)
Older HDSP cards work pretty much out of the box, like Multiface I & II with the pcmcia, pci or pcie adapter card. Run hdspconf and hdspmixer. It comes with alsa-tools-gui in any standard distro.
The AIO PRO is a different beast and needs hdspeconf which needs to be compiled.
This is what I personally ran succesfully
UCX II, BBF Pro FS, Quadmic II, PCIe HDSPe Multiface II, AIO Pro
The Madiface USB does have a class compliant mode. I am running it here connected to a Raspberry Pi 5.
True.
Thats pretty new, the new firmware with class-compliant-mode was released in January this year.
7
You might have also missed USB.IO, USB.MADI, Digiface Ravenna and Digiface USB. We have started to add USB 2 devices that don't have physical switches to change modes, because the solution with Windows/Mac FUTs changing the mode turned out to work so well.
USB.IO, USB.MADI
What is that ?
USB.IO, USB.MADI
What is that ?
https://www.directout.eu/directout-anno … ed-by-rme/
10 (edited by waedi 2026-07-13 20:50:51)
Summarize
The Digiface AVB is the only RME interface not to use on Linux
All other actual  RME interfaces can be used on Linux
Old Firewire interfaces FF400 and FF800 can not run on Linux
Hdsp card needs some special software as mentioned here :
https://forum.rme-audio.de/viewtopic.ph … 34#p251734
Instead of Totalmix one can use Reaper Linux to route all monitoring needed.
11 (edited by ramses 2026-07-13 21:34:02)
Excel: line 92, CC-mode. For iPAD and Linux.
Windows and macOS have native driver support, so I left these two out.
12 (edited by lucafusi 2026-08-21 21:19:42)
Just to chime in on this, I'm using a Fireface 800 plugged into a PCIe Firewire card on Linux, and it's working fine across the system as well as for using Reaper. There are a few guides out there I followed, and I went down a rabbithole of troubleshooting things and trying to overcomplicate my setup before eventually just going with .. the simplest approach. The baseline ALSA audio subsystem, no jack, no libffado stuff. The Firewire maintainer for Linux through 2029 is active and very knowledgeable, and these devices have been so well documented that they do work totally well. You have to set up a couple of pipewire and wireplumber rules, but it's doable, just annoying to wrap your head around if you also happen to be new to Linux as I was.
It's possible through using your huge brain or sic'ing your agent of choice onto the source code for libffado to engineer tools that'll let you hot-flash (e.g. apply settings to the mixer while the system's running) to control input/output levels, phantom power and the like as well; we're in an age where you can roll your own TotalMix replacement if you want to. To be clear, ffado-mixer basically already *is* this, but to use that tool you need to have jack/libffado claim the audio stack instead of the snd_fireface kernel, and I found that wasn't working reliably for my system, so it was necessary to try to build some stuff from the ground up.
I'm happy to share the specifics but just know that generally no one cares to see anyone else's slopcoded TotalMix TUI / CLI tool or whatever. But don't give up on your old hardware! It (and the fantastic driver support that I now miss) is what makes RME so fantastic.
13 (edited by waedi 2026-08-21 22:00:12)
More power to you.
My post is results of looking at CC-mode which those two not have.
You have access to all hardware inputs and outputs from Reaper ?
Yeah, I do. The interface is declared in pro audio mode within Pipewire, which exposes everything, and Reaper is using jack, which talks to pw-jack's implementation. Sorry that I messed that up from memory! I meant only that I wasn't using the full native jack stack and instead deferring everything to pipewire, always, more or less.
https://i.imgur.com/d1P3hMw.png
Looks like this. I'm able to use Reaper playback and e.g. watching something on Youtube at the same time, or be in a voice call or something, it all works fine.
https://i.imgur.com/rDxTquk.png
Extremely crappy behind the scenes TUI totalmix replacement for flashing presets and such. I mostly had to do this because my 1/2 loops back into the headphones path and that's flashed into the mixer; I had no good way to go 'headphones only' without getting up and physically turning my speakers off because that was baked into the flash before I left Windows ha ha
