Topic: Just installed HDSPe AoX M - PROBLEMS (SOLVED!)
I just received my HDSPe AoX M, installed it as per instructions, using current download files, also FW updated.
I tried EVERY possible combination of clocking and streaming configuration using the card's control panel and HIVE, all I get is glitches and noise.
I tried the card as Windows 11 default output, I tried the card as I/O via AVB.. the same
I hear the same glitches and noise over the Headphone output too (even as Win default I/O) so I guess it is not the AVB connections to blame.
The card:
AoX driver 1.2, PCIe Core 67, Network processor 1.3.2
PC:
Win 11 21H2, GA Z390 UD, 64GB RAM, i7 8700K
All the rest of the devices are AAF / MILAN compatible, they work normally together for long now, using HIVE, AoX is the only new addition.
I also tried to clock the card from MADI (I've also got the optional MADI card) and use MADI I/O, always the same noise and glitches.
However, as I am observing carefully the VU meters on totalmix the signal shows as playing normally the audio and NOT the noise.
One last thing: I am using the AoX internal clock as media clock leader to the rest of the system succesfully.
Help!
