Re: TotalMix FX 2.1 released
RME Support wrote:
Which device, driver and firmware is this?
RME Fireface UFX II
Driver: 1.0.26
Firmware: UFX II: USB 26 DSP 30 CC 15 (A)
Fireface UFX II - Babyface - HDSPe AIO - Multiface
jeffcity wrote:
Windows 11
Works here on multiple computers. Are you sure the option 'Store channel open/close in Layout Preset' is active? Maybe toggle it one time to reset...
Yes, I had 'Store channel open/close in Layout Preset" active. I tried the toggle on/off and that didn't work. I actually toggled off, rebooted, then reactivated. Still same behavior.
As a test I opened a layout (via mouse) with expanded input-channel settings, then manually collapsed one channel. Recalling the same layout via ARC USB leaves it collapsed. Clicking that layout in TotalMix immediately restores the expanded state.
153
Still can't reproduce even with this example. Can you please send your workspace?
https://drive.google.com/file/d/1N_iRJm … sp=sharing
Here's a shared link to the workspace. Thanks for looking into this.
155
Ok, it's reproducible with this workspace. Thanks!
With last version, from time to time at start up I have a empty layout instead of the UI
Not sure, but maybe it happens on second screen.
157
Windows computer ?
