It's official, my brain just exploded!
Frank, you’re killing me with JOY! The word AMAZING doesn’t quite capture it all.
As far as I can tell, the SEND/PLUGIN button assignment is perfect! Thank you so much. However, I am now noting prior behavior I think could be improved - when I pick an assigned Submix via SEND/PLUGIN, the corresponding Output row SELect button is not updated/mirrored, it stays on whatever output was previously selected – when I go to the output row, the lit SEL button doesn’t match what is actually selected. It works correctly the other way - selecting one of the assigned outputs via SELect in the output row lights the matching SEND/PLUGIN button.
The “Solo selects Cue” mech also works perfectly, and with the color implementation on the SEND/PLUGIN keys I always know what’s what. And the "Shift/Solo" background Cue selection is brilliant - another way I can avoid accessing the Output Row. So Happy!
Playing with the new Submix selection reminded me ORC will only let you build those submixes when they are Not Hidden in TotalMix on the computer (Options/Channel Layout). If you’re on the Output row on the UF8, or you're assigning the SEND/PLUGIN keys in Settings, you’ll notice pretty quickly those outputs are not there. And it’s easy enough to go to the computer and unhide these particular outputs, and make sure they are unhidden in all Layouts. But if you use the ALL button on the computer to show channels that are officially “hidden”, that button currently doesn't impact the UF8 - I got suckered into that scenario a couple times. Anyway, it might warrant a note in the manual to stress needing to not have those assigned Output channels HIDDEN.
I’m now going to dump on you a bunch of random comments, a lot of nits here, but sorry I’m a retired engineer, I can’t help myself. If nothing ever changes, this version of ORC does everything I need! So please pick and choose what if anything you might want to address.
1) The 360 button light is Always On, rather than toggling along with display of the settings window.
2) The font size of the display “banner” (showing the current Submix on Rows 2 & 3) is TINY – any way to make it any bigger? Probably not, but figured I'd ask.
3) I use Layouts a lot, so I was super happy ORC lets me select Layouts from the UF8. But right now, it is set up with 8 Layouts, while TotalMix only has 6 available Layouts. I'm fairly sure that's how it works - I would love 2 additional layouts, but I don’t think they’re there. Coincidentally, ORC doesn’t currently make use of the ALL and SUBMIX buttons in the Layout section, (no response in ORC, and no UF8 buttons assigned). So, a logical update would be to change Layouts 7 & 8 selections to ALL and SUBMIX selections, if that’s possible. Or perhaps they could be made available as assignable actions. As mentioned earlier, the channels shown/hidden by those buttons are NOT reflected on the UF8 by ORC, so implementing them might be messy or full of unintended consequences. At the bare minimum, ORC ought to only refer to and support 6 Layouts, if that’s all there are.
And I'm noting that on my setup, selecting Layouts that add additional hidden channels can take 5-7 seconds to show up on the UF8, while Layouts that bring back hidden channels seem to be pretty much instantaneous.
4) Can the ORC channel names follow the “Names” button - i.e., toggle between User and Default names as is done on the computer? That’s another one I use a lot. Maybe it could be an assignable action? Even better, If the display would accommodate it, I would love a selection to display BOTH the user name and the default name, but given the limited display size, that's probably a no.
5) How can I Pan, on channels AN1-12 (where the V-POT is Gain)? Obvious solution would be the PAN pushbutton could enable this. Or maybe the VPOT Pushbutton alternate between Gain and Pan? Any way, just a nice-to-have.
6) You’ve added a lot of cool capability on Layers 2 and 3, but I personally won’t use those layers. For live use I would prefer them to be Row Selections 1, 2, & 3, with the button illumination giving clear feedback of which Row is called up. Possibly a Setting alternative selection? Or maybe Row selection could be assignable actions, for something like the Quick keys.
7) Is the UF8 aware of when 2 outputs are “mirrored”? On the computer, selecting one output automatically highlights any others that are mirrored. The obvious choice is to illuminate parallel SELect buttons, but maybe some other method?
All done. Thanks, Frank! Please understand, I will never fully be able to express my appreciation for the work you’ve done matching this to my specific “selfish” needs. I’m hoping other RME/TotalMix users all rush out and purchase UF8’s to experience the crazy amount of sophistication and control you’ve enabled here.
We play the last 3 weekends in November, so I'll be giving ORC a thorough road test :-)
Dave
