1 (edited by repentov 2026-11-04 04:57:35)
Topic: RME Control 3.6 (MacOS)
Menu bar application for controlling RME audio interfaces via TotalMix FX.
Works via Global OSC only with TotalMix 2.1+
https://i.postimg.cc/cH78z7Lv/Snimok-ekrana-2026-10-21-v-20-55-46.png
Features:
Audio Outputs Control & Monitoring
* Volume control for any outputs (including Main Out and headphones) via Mac volume keys or the menu bar.
* Adjustable volume step size ranging from 1 to 10 dB.
* Dim/Mute function using the Mac mute key.
* Mono switch via the SHIFT + CMD + M hotkey.
* Speaker B button for switching to an alternative pair of monitors.
* Quick audio output switching for volume keys using the Option + Up/Down Arrow shortcut.
* Channel editing with the ability to modify existing input and output channels or add new ones.
* Creating sends from input channels to output channels.
Inputs Control
* Phantom power (+48V) control for any number of input channels.
* Instrument mode toggle for any number of input channels.
* Convenient EQ and compressor control.
Interface, Notifications & Customization
* Dedicated always-on-top window for input level monitoring.
* Clipping notifications to prevent signal overload.
* On-screen notifications for volume changes, Dim, Mono, and Mute (these appear even when values are modified directly in TotalMix, and the Mute notification displays the specific output name).
* Customizable application menu.
* Preset system to save and restore all application settings.
TotalMix Integration & Synchronization
* Full two-way synchronization as the application reads values from TotalMix at startup and maintains a stable connection.
* Fail-safe disconnection behavior that freezes values and reverts Mac volume keys to native system behavior when TotalMix or the audio interface is disconnected.
* OSC monitor in the Connection section to track network commands.
Remote Control
* Built-in web server launched within your home network via a single "HTTP server" toggle in the settings.
* Quick QR code connection that opens a full RME remote control right in a mobile browser when scanned with a phone or tablet on the same Wi-Fi network.
What's new in version 3.4
1. Added a setting to toggle whether adjusting the volume unmutes the output.
2. The mute notification now displays the specific output name.
3. Added an Option + Up/Down Arrow shortcut to quickly switch the active audio output for volume keys.
4. Added presets to save and restore all application settings.
What's new in version 3.5
Added an option where activating an output (Option + ↑/↓) mutes all other outputs except the active one (highly useful for mixing and production).
What's new in version 3.6
1. Added a TotalMix input and output scanning feature to the routing section.
2. Fixed increased power consumption (~6 W) that occurred when TotalMix was not running: OSC transmission has been switched from NWConnection to a regular UDP socket
Setup:
1. Unpack the archive and move RME Control.app to the "Applications" folder.
2. Remove the quarantine flag in Terminal:
xattr -dr com.apple.quarantine "/Applications/RME Control.app"
Or: try to open the application, then go to System Settings → Privacy & Security → scroll down to the bottom and click Open Anyway next to "RME Control was blocked...".
3. Remove and re-add the application in the Accessibility settings.
______________
TotalMix:
1. Set OSC Host to 127.0.0.1, ports to 7001 / 9001.
2. OSC Mode: Options → Mixer Settings → OSC → Compatibility (Mode): Global OSC
3. Enable Send Status
4. Enable Send level data
5. Enable Peak hold
6. Enable Send all data on start
Download RME Control
https://drive.google.com/drive/folders/ … sp=sharing
Enjoy, friends!
Re: RME Control 3.6 (MacOS)
Very cool--is there a way to configure which four HW inputs correspond to the 4 MIC/LINE channels? I can't seem to get them to reflect the incoming audio.
3 (edited by repentov 2026-08-28 02:27:51)
App updated, give it a try. Try to find out which Global OSC commands your inputs correspond to and change them in the settings.
Cool, may I ask which software you used for that?
For development?
Open Code, Deepseek v4 Pro
Great, thank you! For some reason, keyboard control stopped working with this new version--the volume slider in the popup with the name of the interface on it is grayed out. But the dropdown menu works correctly.
https://www.dropbox.com/scl/fi/yt3d8f7kv2ul2fjtocpoy/RME_control_b.png?rlkey=bnjr4tg76po6og9bgz9cri5sa&st=z9ce82df&raw=1
https://www.dropbox.com/scl/fi/pz5rg1pirse6ydvc7isfw/RME_control_a.png?rlkey=2v6pwmrua1ga7mzogv2sq119g&st=mionb92z&raw=1
7 (edited by repentov 2026-08-29 21:53:17)
Hi! Please try removing and re-adding RME Control in the macOS Accessibility settings. Kindly let us know whether this resolves the issue.
I also recommend enabling the Peak hold function in the global OSC settings for the clipping notification to work correctly.
8 (edited by AdamBier 2026-08-30 20:49:56)
That worked, thanks! It has to be actually removed (with the "-" button on the bottom of the list); simply disabling and reenabling the app didn't do it.
And the clipping warning works properly once peak hold is activated.
One other suggestion: it would be great to be able to pick whether the mute button maps to dim or mute (instead of always dimming).
Great idea! I've already added this feature to the app.
You can already download it
Excellent, thanks!
hi! thanks a lot for this! my main is different than analog 1/2. with the volume key it controls analog 1/2 not main assigned channels?
Hi! What RME model do you have?
i have fireface ucx II.
thanks!
Awesome..
Works like charm, when I’m too lazy to open up TotalMix or my Ipad is too far away
15 (edited by repentov 2026-09-04 04:46:39)
thanks!
Added the ability to assign outputs to the sliders in the settings. Don't forget to remove and re-add RME Control in the macOS Accessibility settings
repentov wrote:
thanks!
awesome! thank you so much for the update! working perfectly! you are the best!
Would you mind sharing the source files on Drive or Github? That way I could compile it locally and not have to go through the MacOS security steps for self-signed code.
My RME Control -> Levels screen is behaving strangely. The indicator is displayed very small in the right corner, cannot be repositioned, and appears in black, making it impossible to identify the channel name. Additionally, a signal is continuously coming in on a specific channel, even though no cable is actually connected. Both the device and the TotalMix knobs, including the gain knob, are set to the lowest setting. Could the device be faulty?
Hello! Please try the new version of the application; some levels bugs have been fixed there. Also, please carefully check if you have enabled everything in TotalMix that is required for RME Control to function properly.
I will publish the source code on GitHub, but a bit later smile
Hey the Drive link above doesn't allow for download - it says the file is in the user's trash - you have a new link?
https://ghostbay.app
+1
Updated the link
repentov wrote:
Updated the link
Nice one thank you, gonna test it out. What kind of feedback are you looking for?
If you have any suggestions, feel free to share them. Let's make the app better together!
i get all the parameters from the inputs on my UCX II but the levels aren't appearing on the level meter and on the EQ and compressor
27 (edited by repentov 2026-10-21 13:39:38)
Is it only the levels that aren't working? Do the phantom power and instrument mode switch buttons work?
Did you enable these options in the settings?
5. Enable Peak hold
with the latest update now works, thank you!
Really appreciate this.  I have a ARC but it's nice to be able to use my keyboard volume controls again.
30 (edited by stun_puppy 2026-10-26 15:44:10)
One issue on my end.
The headphones volume control doesn't sync both ways.  If I drag the phones volume in the RME control windows it changes the volume in total mix.  But if I drag the phones fader in total mix it doesn't sync with and adjust the volume level in the RME control app menu bar.
Note the master volume syncs both ways and works fine.
Maybe I need to change or setting?
Also one other thing.  Would it be possible to make it when changing volume via the ARC USB that the volume popup window also shows that.  would be nice.
Most likely, you haven't configured the OSC address for the headphones slider correctly. By default, it's set up for my specific TotalMix configuration, so please try experimenting with different options.
Please send me a screenshot of your output settings in RME Control and a screenshot of your TotalMix window—I'll do my best to help you out.
Right now, I'm testing a new feature that links sliders via touch, so setting up RME Control should become much easier soon.
Good idea—I'll do that!
I have added an OSC monitor to version 3.3. You can move the knob in TotalMix to see which OSC address it transmits, and then update it in your headphones output settings
All working now.  I had the wrong assignment.  Thanks.
35 (edited by COBCrew 2026-10-28 00:49:59)
I've noticed two issues with how RME Control handles the Mac keyboard's volume and mute keys:
1. Main Out (speakers)
- Volume control works correctly.
- The keyboard mute key works correctly.
- However, adjusting the volume while muted automatically disables mute. I would expect mute to remain active until explicitly disabled.
2. Phones (headphones)
- The keyboard mute key does not work.
- When the headphones are muted in TotalMix FX, adjusting the volume using the keyboard correctly preserves the mute state.
Ideally, both outputs should behave consistently:
- The keyboard mute key should work for whichever output is selected.
- Adjusting volume should not automatically disable mute.
Is this intended behavior or something that could be fixed in RME Control?
I love this, thanks so much!!!
Added the option to customize mute behavior in version 3.4.
I’ve tested it on my end, and it seems to be working fine. Could you please try it on your side to see if everything works for you now?
Hi there, this feature is amazing! I'm having a small issue tho, the keyboard control works but my output volume remains unchanged, am I doing something wrong? I'm using a fireface ucx II and totalmix 2.1
Hi! Please check if you have configured TotalMix correctly. There is an instruction manual in the header. Check if the OSC addresses are set up properly. You can open the OSC monitor, move the corresponding knob, see its OSC address, and enter it in the settings under the Routing section.
I have the same issue yikes - ucx ii and totalmix fx 2.1
osc monitor shows /output/4/volume when I move the main fader in totalmix - which is what I input in Channel OCS address, which outputs /level/out/4 in Levels address...
Kristoffer
Kristoffer
Levels automatically adjust to your output. Please send me a video of your issue, and I will try to help you out. I feel like everything should be working.
Where are the preference files for this?   I can't seem to find them and have accidentally added all channels and now can't scroll the list of channels.
Also. which Accessibility setting is we need to toggle and or enable?
/Users/your user/Library/Preferences/com.rme.volumes.plist
In the General section under Accessibility, click Open System Settings, remove RME Control from there, and then add it back
Kristoffer
Version 3.6 did it ! it works beautifully ! Thanks
Great, thank you
46 (edited by stun_puppy Today 00:38:56)
In the settings is there anyway you can add an option to disable the mono hotkey or let us reassign it.  On mac it's interfering with the Ableton hotkey to create a midi clip ( command/shift M).
And would you consider making this open source like a github repro?  I think it'd be fun to play with.
