1 (edited by dilly 2026-10-31 15:24:13)
Topic: Are these names wrong under WinRT in Cubase?
I was wondering if something is wrong here with my installation, which I have tried to fix and have already reinstalled latest version.
Under Cubase MIDI Ports WinRT I see these choices, which seem to have the wrong names.
Capture
MIDI
MIDI
MIDI
MIDI
Render
In WinMME it shows the correct names.
Does anyone know something about this?
Also says the same in Device Manager->Software Devices. "capture, MIDI, MIDI, MIDI, MIDI, Render"
This is Win10 machine, everything else is working finely. MIDI works fine, too.
thanks
Re: Are these names wrong under WinRT in Cubase?
and these names are ?
3
And what audio interface and which driver version  and which Cubase version is this about?
I might have to check but AFAIR our driver is not WinRT based, so this might be a normal side effect.
4 (edited by dilly 2026-11-01 03:03:04)
It's RayDatHDSP
Driver 4.62
Cubase 15 (or any)
The 'Capture' and 'Render' been shown in Cubase seems odd. Talking about it to chatbot it says those underlying endpoints rather than the user-facing device name.
If there was many ports it would be so confusing working in Cubase.
I would expect the names to be (same as MME)
RayDAT Midi Port 1
RayDAT Midi Port 2
But seeing the generic names in Windows Device Manager->Software makes me wonder because I don't think that has to do with 'WinRT'.
thanks
5
Chatbots say something different, try a simple 'wrong MIDI names in Cubase WinRT' request.
So,
"Generic USB "MIDI" Labels: WinRT MIDI attempts to read device names directly from the USB descriptor. If a device manufacturer did not program a proper friendly name into the device's firmware, Windows/WinRT defaults to calling it a generic name like "MIDI".
Is that right? I thought it worked previously, but I wasn't sure.
thanks
How would WinRT see if a username for a Midiport is friendly or not.
It will use own generic names anyway.
8
There is no USB descriptor in a PCIe device...
And I just got confirmation that our drivers do not support WinRT anyway, neither for audio nor MIDI.
Ok thanks for the reply.
I thought WinRT was something added in updates. Ok.
