Topic: Digiface Dante as Live Professor i/o vs HDSPe in a Chassis
Hi all,
I have tried to search up some results in the forum relating my specific questions, but nothing completely covered what I was asking.
I have been running a Live Professor rig on my MacBook Pro for the summer and it's become a staple of my show. Now, I'm looking into making a dedicated rig.
I was using a Digiface Dante connected via MADI to my Digico 338. It seemed to work well, I could get my buffer down to 64 samples  at 96k, anything lower than that caused drops in audio and errors.
I was considering moving to a HDSPe MADI card in a Sonnet chassis for the dedicated build, I was trying to find definitive data about the difference in processing time or any improvements between the interfaces, I could find nothing concrete.
Is a PCIe over thunderbolt based solution going to offer an improvement over the Digiface Dante with regard to transport speed or lower possible buffer settings?
Further to that, is the AoX series an improvement over the older generation. I don't need Total FX or anything.
I'm doing monitors, mostly so low latency is my biggest consideration.
Thanks in advance,
Chad
Re: Digiface Dante as Live Professor i/o vs HDSPe in a Chassis
Did you use the DriverKit or Kernel Extension driver? The DK driver has been much improved lately.
I tested the latency from the AOX Madi vs a Madiface USB on a M1 MacMini. And the latency is almost equal. Actually the Madiface USB is a few microseconds faster. This due to extra safety buffers on the Thunderbolt connection in the MacOs. On a Windows machine you could gain some latency. The Dante latency comes on top of this Thunderbolt (PCIe) Latency. The advantage with the AOX in a Thunderbolt chassis is that you have a lot more channels and a Thunderbolt connection, which is very stable.
Audio AG Support
Hi.
I'm on Driver Kit, I think (v4.27 at the time I was on tour)
Interesting news about the Madiface USB being a bit faster, I would not expect a USB device to outperform a PCI card in any capacity, but that also shines a light on my ignorance of the architecture of these systems. I was planning on getting a Mac Mini M5 Pro to run all this.
I wouldn't know what's out there in the PC market that is comparable in size, power and cost.
But it also brings up another important point; stability. I want something that I feel confident in and while the Digiface Dante was rock solid for me I am prepared to spend a buck on something that is a genuine upgrade.
The AoX seems like a good option that would allow me to move between Digico and Yamaha consoles and not have to swap out or repurchase any components and have comparable latency specs between Dante/Madi systems, but it's considerably more expensive than the standard HDSPe MADI cards, so if there's no real difference in Madi performance between them it makes this decision a little harder for me.
Thanks,
Chad
Because it is thunderbolt
My voting point goes to USB device over PCIe because an external box can be out of the way then.
I bought AOX-D with a MADI card for using plugin while doing live sound.
Digiface Dante is also have lower latency than AOX-D with PCIE enclosure.
But I really like AOX-D is it can handle more channel if you'll mixing live with 96k you might need more than 32 I/O.
And that you can't done with Digiface Dante.
