Topic: Problem with Mulitface II PCIe cannot load driver!!
I am new to this card. I had 3 HDSP 9652's and moved to the new Multiface II. I am using it with Vista Ultimate Intel i7 Core 3.06 chip. My main sequencer is Sonar 8.5PE. It was working fine and then suddenly I was getting a message that this audio interface in not recognized by your computer. I went into control panels/device manager and there is little yellow warning triangle by the RME Hammerfall DSP speaker. I searched for drivers, and it said that the RME Hammerfall DSP was the correct driver. The device status gives me the following message:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
The button to "Roll Back Driver" is greyed out. So what should I do. I have tried unplugging and re-plugging the firewire cable and re-booting.
I would appreciate any suggestions you might have.
Best,
JL
