Topic: Fireface UC cracks, drop-outs, pitch etc... On windows
Hi there,
I just bought a RME fireface UC to change my previous Fireface 400, because I was tired of Firewire incompatibilities.
My system is:
CPU: Intel Core 2 Quad Q9550 2.8Ghz
Motherboard: Gigabyte GA-EP45-DQ6
Memory: 16 Gbs DDR2 OCZ Platinium
Soundcard: RME Fireface UC
Windows Vista business 64bit
And the result is that I'm pretty desperate, when I run VLC I can read the music but with lots of drop outs and cracks, Windows media Player accelerates the tempo, and transposes the notes.
First of all I've installed the soundcard on Windows 7 bit, and I realised that RME FF UC software doesn't support W 7 64bit... I read the instruction and installed it well through the task manager etc... But I encountered cracks, dropouts, tempo problems, and high pitched sounds, even for internal PC sounds, so I switched to Vista 64 bits and had the very same problems !!
My aim is to make it work with Cubase 5 64bits but if it dosn't work with PC sounds and integrated players at first...
I bought RME for its legendary stability... But here I have no answer to solve this...
All the best,
Prophets
