Since I'm always willing to give it one last try...
vocaltrance wrote:Individuals at RME would prefer curt rolled up eye smiley faces to a serious matter of non-working drivers for windows 7 as evidenced by my problems and at least 3 other threads on this site.
As we've pointed out, these issues are unrelated. And if there were a "matter of non-working drivers", don't you think we'd be seeing more than three threads?
Someone at RME has mistaken the time I am spending troubleshooting RME garbage drivers as not valuable.
If at least you had done semi-serious troubleshooting and proved something beyond doubt, you'd be entitled to do some insulting... But you haven't. You tried one computer. You tried one DAW software, in an outdated version. What does that prove, and more particularly what does it say about Windows 7 or the FF driver under W7? Correct, nothing. It only proves that there is some issue on your individual setup. There are, however, plenty of potential causes, which unfortunately, you choose to ignore, since you have decided it must be the RME driver and nothing else...
3.034 works like a charm on my self-built i7 machine. I can run Sequoia projects at constant CPU load way beyond 80 % (on an i7, that takes a lot of plugins...) with no glitch or crash. Apparently, it also works on plenty of other W7 systems. This IMHO pretty much rules out the combination of FF driver and W7 in general as the culprit.
Try Reaper. Try another computer. If you can prove it is a driver issue, and if we can reproduce it, we'll gladly do what we can to fix it.
