Topic: RME 400: weird / sporadic slowdowns on recording...
so i'm a dj.. and i recorded an hour long set (a few times) and what I am experiencing is never heard before:  upon playback of my recorded material: out of the blue in a constant stream of sound.. a slowdown in audio or pitchdown.. that lasts no more than a a couple of seconds.. then goes back to regular play..  but it's peppered through the hour-long mix...
i use the RME 400 at 44.1Khz.. i have disconnected it properly/turned it off-on/ upgraded the firmware/ but seems like it continues to happen
it's connected to a Windows XP machine...
it works great for the most part!  but these pitchdown spots are not acceptable!
has anybody experienced anything like this?
kindly yours,
L
Re: RME 400: weird / sporadic slowdowns on recording...
Have you got Windows trying to play system sound on the FF?
I am pretty sure I disabled systems sounds from Windows but I will check this again today. Thx
4 (edited by logic010 2011-02-07 19:53:55)
confirmed:  system sounds was disabled.   i did have analog 3+4 however set to output the computers audio (internet, itunes).. so i will be disabling that when recording.
also, i had my two inputs going into the two front analog 3+4 set as Instrument instead of Pad.  that would have affected the input stage by 12db.. but not sure it would have caused these "slowdown dropouts" in recording...
What software are you recording with? Is Midi involved?
i'm recording with ableton live 8.1.3.. midi is usb midi
issue solved... essentially disabled simultaneous playback of windows sounds (not system sounds but browser, itunes), while recording
