Topic: Rme 96/36-52 + Apple Station Troubles :-(
Hello
i'm setting a workstation with an Apple g4 dual 1,25 ghz processor 2gb ram ,
an rme 96/36-52 pci card (v1,5 , as i see printed on the card)
the system is osx 10,4,11
and the sequencer Logic 8,02
* - there is something wrong in this configuration ?
***first trouble i found : the osx audio-midi control panel (when 96/36 is selected as device)
show in mirror and closed all the faders that contros channels input and output (from 1 to 18)
and it's not possible move them
it's normal ?
***second trouble :
i connected the 96/36 adat out to adat in (same card , for make a test about  in-out adat connections (and card),
in logic 8,02 , i opened a stereo audio track , with an audio file in play ,
the out of this audio track is switched sequentially to adat out 1 channels 1-2 , 3-4 ,5-6,7-8 ..... (also 9-10,11-12,etc....)
then i opened another stereo audio track as input signal monitor,
with this input stereo audio track i want to see the signal come from card adat out 1 , and channels 1-2,3-4 ,etc...
but unfortunately the meters of the input track don't move signal don't arrive
(output of this input stereo track go to bus 24-24 , and the bus 24-24 is without any out for avoid feedbacks at master)
i do something wrong ?
is the card broken , or need firmware update ?
there is way to check about  ?
any help is wellcome ,
thanks in advance
H.:(
Re: Rme 96/36-52 + Apple Station Troubles :-(
You may have the wrong EPROM installed on the card. For Mac, you need M36 (for DIGI 9636) or M52 (for DIGI 9652).
Otherwise, I don't understand what you're talking about...
3 (edited by hammerfaller 2011-05-31 21:47:10)
thanks for post
seem you are so right ,
i also made a check with mac os 9,2,2 system and logic 4,8,1 (same configuration as in logic 8,0,2) ,
and the problem seem the same ,
then or the card firmware is corrupted , or wrong , or card is broken ,
where can i check if eprom is right ?
let me know
peace!
H.
Just have a look whether the EPROM says M or W...
thanks for post
where is placed the "M" or "W" on the card ?
peace
H.
There is an EPROM on the card, on top there is a sticker with the EPROM type printed on.
7 (edited by hammerfaller 2011-07-28 22:22:51)
thanks Jeff !!
after thousends of test etc....
i get another 96/36 card and now many issues but not all are "solved"
( i also called the guy who sold me the card ....as full "working" ..
and
my "friend" (big and fat ) bring the card back .... , also "said" something in the ear of that "guy" ..)
now the probably "final" issue  is about a strange "glitching" ....(like dat apackage interruption)
i connected the adat out 1 (channels 1-8) to the digidesign adat bridge input 1
audio signal from 96/36 arrive without stranges delays ,
but any 5-10 seconds also glitching "pops" and "cricks & cracks" arrive ....
(only when audio signal is present)
i checked all possible buffer settings  inside logic 8
cpu meters of logic 8 show 10% to max 50% (then no cpu overloads)
what can be ?
thanks from now for any help,
peace
H
but
Seems like clocking is configured wrong. Check settings of the card and setting of the external device.
9 (edited by hammerfaller 2011-07-30 16:05:05)
Hello Jeff , thanks a lot for reply !
the clock is set to " internal" (pro tools)
perhaps  i have to  connect the word clock out of adat bridge
to the word clock input of the 96-36 ?
.. i don't see word clock connection on the 96-36
thanks on advance
peace
H.
Open the DIGI settings application, and tell us the clock setting there. Also any external digital device clock settings.
