Topic: DUrec indicates 22 Tracks but records 19 or 20?
I am using two UFX (one as a slave/mic pre/converter). As previously posted I have used a Crucial SSD as the recording media. The front panel of the master UFX indicates 22 tracks are being recorded with approx 50% USB and no errors for over 2 hours. Per the WAV file labeling the DUrec appears to drop one or two tracks from each UFX.
Not sure which inputs are affected but I know that the 22 tracks are legit since I routinely record them, simultaneously, to Pro Tools 10 sessions. However, there are only either 19 or 20 tracks, consistently, being recorded. There's no problem going over the 2 Gig limit since the overlap tracks are relabled and recorded but whether I record long enough for overlaps or not the (reduced) track count is the same.
Do you have a fix or workaround? Thank You
