Topic: Kernel Panic - the Saga continues....
Hey people,
When I first bought the RME Babyface, I installed the latest drivers and I got kernel panic after kernel panic on my Macbook.
I am using OSX 10.6.8 and luckily I had backed up.
Since than I have painstakingly clean installed a vanilla 10.6, freed up hard drive space, bought new RAM and worked my way through every OSX update (10.6.1, 10.6.2. etc) until I had a stable, useable system. I do not have any of iLife or design programmes installed as I am using the Macbook for music purposes only.
Since updating to the most recent drivers( version 0.984) for the Babyface I am getting kernel panics again at application launch?
Can anyone offer an explanation as to why this might be happening again? Is it a latest driver issue?
I was very reluctant to update to the new drivers because of the immense effort I have put in to get this interface working, which I may add has been incredibly stable since I troubleshooted.
When I update to the recent drivers, do I also need to use the flash update tool to check for new versions? because I haven't done this?
Re: Kernel Panic - the Saga continues....
Latest driver version for Babyface is v 1.75, are you talking about the TMFX version?
If you are running driver v 1.75, you need to have firmware v 185 flashed to the unit. Check the Fireface USB settings app, current versions in use are listed at the top.
Jeff, I'm running these firmware and driver versions.....
I'm not sure what I can do now, would you suggest going back to the earlier version i.e. will I reinstall my Hard drive to
the earlier driver version from Time Capsule?
Or would you please know what other solutions I may have?
Hi Jeff,
Thanks for the quick reply the other day but I have yet to find a solution to my problem.
I am a consumer, not a technician so I am wholey reliant on customer support for problems that crop up.
I realise that it has been the weekend and support might not be available and I am just letting you know that my
difficulties are still here.
Can you tell me if I should restore my system back to the driver version previous to the most recent update?
If I do this, does it or will it cause problems with the Babyface?
In addition to the kernel panics, the TMFX fader gains are moving along with the fx send when I am applying fx to
the mics?
I have reset TMFX but the problem persists.
Thank you in advance.
Brian
Swooooosssshhhhhhhh.......the sound of tumbleweed moving across this thread............:-)
