Topic: UCX Free Submix MIDI Control in Standalone Mode
Hi everybody,
I have seen different posts on controlling TotalMix via MIDI or OSC, but haven't found any topic matching my problem:
I want to use my Fireface UCX in standalone mode as a portable digital mixer that can be controlled via MIDI messages. Unfortunately I cannot use the Submix View because all channels are routed to different submixes and I need to be able to control their volumes simultaneously.
Is there, or will there be a possibility to control every point in the mixer matrix via MIDI CC in standalone mode?
I tried one solution: sending two messages for every fader movement. First select the submix (e.g. "ch13 cc106") and then set the volume (mackie control: "ch1 pitchbend"). Like this, it should be possible to change two submixes at the same time. It works, but fast fader movements introduce a noticable lag of up to 1 second, because the submix is re-selected many hundred times per move. Did anyone try something similar?
And I could not get that submix CC to work when USB is not plugged in. The mackie control "REC/RDY" button mentioned in the manual didn't work either. The corresponding message should be "ch1 note on C-1". Is that right?
Best regards,
Sebastian
