Topic: output of the Babyface
Helly every Rme users
I 've plugged the phones out (via jack)to connect directly to my hifi amp but the sound is not bad but not so top,
Would it b better if i plug the xlr output and if yes ,how to connect it to the rca input of my amp?
thanks
2 (edited by Max 2012-11-20 07:57:46)
Re: output of the Babyface
Hi Enolys,
first make sure you're not using the phono RCA. Then, make an adapter to RCA as described in the manual section 27.2.
3
To clarify: Max talks about the equalized long-play record input for MM (moving magnet) or MC (moving coil) cartridges. Use whatever else.
Sorry for my silly question,but if i plug stereo jack to female jack (phones) will i have the same sound as if i plug 2 jacks to xlr main out
thanks
