1 (edited by Immersion 2013-04-03 03:37:42)
Topic: Will this cable work ?
Can some one tell me if this cable will fit with my HDSPe AES 32 PCIe card ???
http://www.mogamicable.com/category/pro … 25-XLR.php
I am going to connect it to my monitor controller/DAC Dangerous Audio Source unit into the AES IN.
http://dangerousmusic.com/products/source
Any help is deeply appreciated since this is a real jungle.  Too much different cables..
And These Aes cables are expensive so I want to be sure I buy the correct cable.
Re: Will this cable work ?
Looks fine. The RME card uses TASCAM pinout. Make sure the DB-25 is TASCAM also, the spec sheet at this link does not specify pinout.
The name of the cable is
"GOLD AES TASCAM/DIGI FORMAT"
this is the info about the cable before you press the "learn more" link
"Based on the technology of our acclaimed Neglex analog cables, Mogami Gold Tascam/Digi Format cable fits all digital recording machines that use the Tascam AES pinout. Extremely sturdy, the Mogami Gold AES Tascam/Digi Format is eight channels in and out, DB25 to male and female XLRs.@
http://www.mogamicable.com/category/rec … e/digital/
Then it should work.
