Topic: Strange quirk with Digiface Dante (WDM Device Configuration)
With every RME interface I've owned (10+) when I select/deselect devices in the WDM Device Configuration window, and then hit "OK", WDM devices in Windows are updated shortly after. However, with the Digiface Dante after hitting "OK" nothing changes based on my selection, and I have to hot plug the USB connection.
Manual seems to state that devices will update without a hot plug as well. Page 15, section 7.2 "WDM Configuration":
https://www.rme-audio.de/downloads/dfac … df#page=15
After leaving the dialog with OK the WDM devices are reloaded so Windows sees their new properties.
Anyone else see this behavior?
system info
# firmware revision
56
# driver version
0.9831
