1 (edited by Rationalizer 2011-01-24 22:22:15)
Topic: PT9 and Fireface 400 question
Hi all! I'm sorry if this question has been already answered (I did search but couldn't find an answer).
I have a Fireface 400 and recently got Pro Tools 9. I'm having difficulties to play from other audio sources (for example Youtube, WMP, etc). when Pro Tools is on. I've configured the inputs and outputs in PT so that it shouldn't use Fireface's playback channels 3&4 which I use for other playback. I'll attach a pic of my Pro Tools i/o settings. Both the input and output configuration are exactly identical.
In TotalMix the playback channels 3&4 are routed back to my monitors which are on output 1&2. These settings work great on Ableton Live.
EDIT: Forgot to mention that both PT and Windows are set to 44.1.
http://lh3.ggpht.com/_BwIN-0UY7mw/TT2UvcCkxKI/AAAAAAAAATA/LTSGkFvqkrU/s640/Pt9.jpg
FF400 | WIN7 x64 | PT9.01 | Live 8.2.1 | Adam A7 | UAD-2 | LA-610 MK2 | TLA A2 | etc.
Re: PT9 and Fireface 400 question
These settings are misleading as PT9 seems to grab all ASIO channels, no matter what you do.
Thank you Matthias for the answer. That being the case I'll have to settle for my on board sound device (which I really rather not use).
Cheers and thanks again.
