Topic: Installing the PCI Interface Card - which way?
I've been using my Digifaces very successfully with my laptops, first with the older CardBus card and most recently with the ExpressCard interface.
Now, I'd like to work with a 1U computer, and I'm trying to install the PCI Interface Card (I have a Rev 1.5 card and a Rev 1.8 card.)
My confusion is due to the 2 small slots on the edge of the Interface Card. There is only 1 small slot on the PCI card on the MoBo. I am able to install the card facing in either direction, which can't be right (can it?).
Here are some photos. Because the computer is 1U, I have to use a PCI Riser Card to accommodate the RME Interface Card
As you can see, I'm able to install the RME in EITHER direction. But which direction is correct? I don't want to damage the card by experimenting.
Thanks,
Ira
