09:15:33.5560455 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5564032 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\MUI\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5564787 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\MUI\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5565727 TotalMixFX.exe 4296 RegQueryValue HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\HTML Help\TotalMixFX.CHM NAME NOT FOUND Length: 144
09:15:33.5616530 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\mui\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5617614 TotalMixFX.exe 4296 CreateFile C:\Windows\help\mui\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5621524 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\mui\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5622445 TotalMixFX.exe 4296 CreateFile C:\Windows\CompHelp\mui\0409\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5623183 TotalMixFX.exe 4296 CreateFile C:\Windows\CompHelp\mui\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5623960 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\CompHelp\mui\0409\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5625961 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5627902 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5631049 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5633557 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\MUI\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5634330 TotalMixFX.exe 4296 CreateFile C:\Windows\SysWOW64\MUI\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5635241 TotalMixFX.exe 4296 RegQueryValue HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\HTML Help\TotalMixFX.CHM NAME NOT FOUND Length: 144
09:15:33.5639758 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\mui\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5640564 TotalMixFX.exe 4296 CreateFile C:\Windows\help\mui\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5644250 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\mui\0409\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5646006 TotalMixFX.exe 4296 CreateFile C:\Windows\CompHelp\mui\0409\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5646841 TotalMixFX.exe 4296 CreateFile C:\Windows\CompHelp\mui\0009\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5647589 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\CompHelp\mui\0409\TotalMixFX.CHM PATH NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5649576 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
09:15:33.5651614 TotalMixFX.exe 4296 CreateFile C:\Windows\Help\TotalMixFX.CHM NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
