Topic: totalmix FX (firface UC) is to big for macbook pro 13inch!
the totalmix FX mixer window is to big for a 13inch macbook pro, see screenshots:
http://img121.imageshack.us/img121/448/ … 8at956.png
with the external monitor as main window it looks like this:
http://img696.imageshack.us/img696/984/ … 8at959.png
can´t the window be resized?
Re: totalmix FX (firface UC) is to big for macbook pro 13inch!
Try the 2-row mode. Works fine on my 1024x600 Netbook screen.
this works better, you´re right.
it still happens that if I change from my 1920x1080 external monitor to the laptop screen that the totalmix window get´s locked like in my first link. the thing is it can´t be dragged; turning 2 rows on doesn´t help in this case.
workaround: turn on mirroring of the displays & then resize it manually.
But if I forget this procedure and go somewhere and don´t have my external monitor with me (which is more often than not the case) I´m in trouble...
I hope my description makes sense.
Thanks for the information, we'll try to fix this.
I understand that fixed width and height of the channel strips is putting less stress on the CPU but you could at least add some options for width and height of the strips and still keep them "static" from the programmer view.
I think that an option for constant gradient and quantized "LED rectangle" bar would be a good improvement.
Fireface-UFX, Mac OSX 10.6, Logic 9, BCF2000, AC-7 user, vocalist, live sound recording
6
khmbp, please use this workaround:
- In the TotalMix menu use 'File - Close window'
- Open a new window with 'File - New TotalMix Window'
In case only a single window had been open before (which is true for you) it will have the same mixer state as before, but be positioned correctly.
hi MC,
I can confirm this is a workaround that fixes the problem for me.
thanks!
