Topic: Sudden crackle and increased latency CB5+Multiface2
Straight to the point:
When I record audio there's a sudden crackle and the latency becomes something like ,5sec. I then open the RME control panel and switch the buffer to 6ms and immediately back to 3ms and the latency is back to normal.
I'm monitoring through my computer with plugins in the monitor path. The CPU meter in cubase hasn't been higher than, say, 15% at any time during recording. I'm recording at 48Khz 32bit with 3ms buffer.
So the computer should easily be able to handle that, and in the past it has. My signal path is as follows:
Source-Soundcraft 6000-RME Multiface-Cubase 5-RME Multiface-Soundcraft 6000
My computer setup:
-WIN7 64
-Cubase 5
-ASUS P6Tse
-Intel i7 920
-6Gb RAM
-GF9400gt
-UAD1
-RME HDSP PCIx2
I just installed WIN7 clean again and set my bios to default. The problem seems to happen every 5-10 minutes or so.
Any help would be appreciated.
I only use the computer for audio work so netwotk adapter and such are disabled.
I realise This is not a very accurate description of my problem but I'll answer any questions you might have.
Thanks in advance.
T
