Topic: Strange behavior of Fireface UC
Strange behavior of  Fireface UC - since today it worked OK , but today when I want to rise or down level with the rotary encoder , it do left or right pan  - then when it gone to L100  rise  level on TotalMix FX sad:(:(  ...(093b2).
On unite I set L.1 to rise or down the main level ...
Some help ??? sad:(:( ...
RME: FireFace UC , Windows 7 Home Premium (x64) , iPad Air .
Re: Strange behavior of Fireface UC
Sounds like the "Stereo Link" is not active. Push in the knob until the screen says "On".
Thank you Jeff , that problem was as you sad - Sounds like the "Stereo Link" is not active. Push in the knob until the screen says "On". ...
Can you tell me , if it is normal - when I turn on Fireface UC unit , input 3 (on unit) is RED , then goes input 4 ,then 1 and 2 together is RED , then HOST is RED and at the end all goes to main screen that show 15 ( or 32 or .... where it was at last time )...
I sad that because - before I didn't see that sad:(:( ... maybe something is wrong ???
Thanks .
