Topic: Firewire question in Pyramix.
I am having trouble with Fireface in Pyramix.
If I change or update drivers it will sometimes go away.
The program will say play but the transport wont move.
This has happened on two different computers.
If I install hdsp it works fine (but I like the fireface).
Somewhere on the forum I saw texas instruments driver info. not sure...
Re: Firewire question in Pyramix.
I've had this happen, and I think it's a bug in Pyramix, so perhaps this discussion is off topic for this forum.
Sometimes going to the "Configure" page in the Pyramix mixer and then back will force a mixer rebuild which will clear this condition, other times, you have to restart the program. In the cases where this has happened to me, it's been when I have taxed the processor with a some hungry plug-ins. Thankfully, I've been able to save my session before restarting the program. Pyramix version 7 is much better with its VST plugin handling, as I'm seeing much lower CPU load statistics.
Something else to watch out for is a random crash while recording - seemingly out of the blue - where the Pyramix audio output will suddenly get stuck in a loop (I think the loop is the same length as the Fireface's buffer setting, so maybe this brings things back on topic). The only way out of this is a hard re-boot. It's happened to me twice in session - very embarrassing - but thankfully my SPDIF connected backup recorder was able to continue recording without interruption. Apparently the Fireface will continue to output a signal routed directly from the Mic/Line inputs to the SPDIF output (in TotalMix) even though it's outputting the looping audio through the conventional Monitoring channels. This suggests even more strongly that it's a Pyramix issue, so perhaps this discussion is off topic after all. Sorry about that.
Windows XP Pro 32 bit, SP3 on a late 2007 MacBook Pro (version 3.1) running Bootcamp 2.1. Fireface driver 2.9992; Fireface firmware 2.77.
Frank Lockwood
https://LockwoodARS.com
Fireface 800, Firmware 2.77
Drivers: Win10, 3.125; Mac, 3.36
