Topic: ADI 8 - QSM / HDSPe MADI / Cranesong HEDD set up
I was hoping to integrate a Cranesong HEDD unit into my system using the digital AES I/O connections to the ADI 8 QSM. The ADI 8 is connected (by BNC) to an HDSPe PCI MADI card and my DAW is Ableton 8.
Routing the audio out of Ableton into the HEDD unit is detected but the output from the HEDD back into another audio track set to external in with the receiving channel out does not reflect the change to the audio applied by the HEDD unit. I've checked the word clock connections with the HEDD as master&slave but was not sure if this set up is possible due to conflict with the existing MADI connection.
(analog connections are OK)
Any guidance appreciated
