Topic: FireFace 400 OSX says 64 bit but dose not run in 64 bit
I am having troubles seeing in what way the latest driver 2.9 is running in 64 bit mode in snow leopard.
When I check in the activity monitor all my softwares run in 64 bit mode except the fire face mixer fire face settings application and the fireface agent.
Iv also tried like logic right clik the program icon in the program folder and then choose info. And see if I can uncheck the box where you can choose to not run in 32 bit mode.
Maybe there is not much differens in performance for this matter but Im sure id would be nice to be able to run it as is says in 64 bit mode. And that when I go into the activity monitor in osx I can see and confirm that it is beeing run in 64 bit mode.
I would be thankful for any advice.
Kind regards
/Gstone
