Topic: playback speed problem with ff800
hello,
i am having an intermittent problem with playback speed from my daw. i am using a high sample rate of 32bit at 192khz. the daw (cockos reaper), will record tracks but then play them backat 4 times the speed through the ff800. i can cheat by taking the playback speed down to 0.25 to hear the tracks played properly. i cannot do anything usefull with the project however as any mixdown plays back again at 4x speed. i have tried other daws i.e. cubase le4 and adobe audition 3 and still get the same problem.
this is intermittent as other projects at the same sample rate play without a hitch. i have a windows xp 32 system with intel core 2 duo, 3ghz with 3.25gb of ram. hard disks are defragged and clean, the firewire card has a t.i. driver, latest version, rme latest drivers.
this is driving me nuts, any pointers would be much appreciated.
