Topic: adat device out of sync with ff800
i took a mono signal, split it with y cable, and ran it into my fireface and the adat device (behringer ada8000) that's supposed to be the slave, then recorded. when i looked at the waveforms they were off by about 30 samples. when i summed to mono you could hear it. very obvious.
so what's going on here?
the ff has a solid green light for adat 1. i thought that meant sync. i'm using 2 toslink cables. behringer ada8000 out to ff in. ff out to ada8000 in. ff is set to internal.
the only thing i can figure is the converter paths take 30 samples longer in the ff.
