Topic: MIDI and RME HDSPeMADIFace
hallo friends
I have RME HDSPeMADIFace on notebook HP Pavillon dv6000 and use cubase5.
I use the Allen&Heath iLive T112 with iDR48 and M-MADI card options connected by coaxial cable RG59 on RME.
Fixed installation problems everything seems to work fine.
The problem is:
Having midi devices including the mixdesk for the totall recall and automation let me know if I need more cards RME additional MADI TO MIDI, if they exist, because even with such a Tascam us144 as You see it only as an input and not as outgoing as well as the Windows MIDI.
I also understand if it is required to disable the onboard audio, I also had problems installing or here if you can fix it somehow.
Thanks and I hope you can solve my problem.
Waiting for news
greetings
Fabiuska
