Topic: RME fireface 400 question about acoustics lab use (headphone output)
I have had my FF400 for about 3 years and it has performed flawlessly.
I have a question though...I use it in a transducer design lab and I need to do some complex impedance analysis
of an ultrasonic microphone design.
Could you please tell me what the current capability of the headphone outs (7 and 8) are?
I know output impedance is about 30 ohms.
Is it short circuit protected?
I'm measuring devices that appear as a few hundred to a thousand pF at most frequencies except resonance, where motional
impedance makes it about 100 ohms resistive. I want to measure at just a few volts excitation.
If you could tell me the op amp used I could hunt it up myself. Just wondering if I need a buffer.
Thanks,
Les
L M Watts Technology
Re: RME fireface 400 question about acoustics lab use (headphone output)
4580, should be no problem.
Thanks, Matthias.
The FF400 has been an excellent piece of lab gear. We use it in the production mic response
testing station as well.
Les
