Topic: Midi Remote Problem
My setup:
HDSPe MadiFace
2 x Micstasy
1 x ADI 648 with some Oktamics via ADAT
I have tried to remote all three devices, the two Micstasys and the ADI 648 with my laptop via Madi.
But when I put all together the two Micstasy are not remotable any more.
State:
Micstasy 1   :Bank "01" Device ID "01"  Name  "Micstasy 1" State  "No Response"
Micstasy 2   :Bank "01" Device ID "02"  Name  "Micstasy 2" State  "No Response"
ADI-648       :Device ID "00"  Name "DEVICE ID00"  State "Online"
When I dispatch the ADI 648 and use only the two Micstasys, everthing works fine.
Chain: MadiFace out - in Micstasy 1 out - in Micstasy 2 out - in MadiFace
When I put the ADI 648 at any position of the chain I am able to remote only the ADI 648
Micstasy 1  is set to Bank 1 Device ID 1 manually
Micstasy 2  is set to Bank 1 Device ID 2 manually
ADI Devie ID 00
and the Remote Input is set to
OPTN Micstasy
Madi ADI 648
Is it possible to remote all Devices ? Or is there a mistake ?
Thanks for advice!
Peter
Re: Midi Remote Problem
You have to loopback a physical MIDI cable on the ADI-648. This means, connect MIDI out on the 648 to MIDI in on the 648. Otherwise it does not pass MIDI data to the MADI output.
Hi Jeff,
Thanks for that hint. It works fine now!!
Peter
