Topic: Totalmix FX Workspace /Snapshot MAC/PC
I'm trying to load a snapshot or a workspace on a mac which i have created with a pc but it is not possible to select these files in Totalmix FX on the mac. Any Hints for that problem?
Thanks,
Andreas
Re: Totalmix FX Workspace /Snapshot MAC/PC
You used the menu with 'Load Workspace' to do that? Double click on the file or Drag and Drop is not supported.
3 (edited by Everfight 2011-02-19 15:34:35)
Yeah I used the menu "Load Workspace..." but I couldn't select the files. I also opened a copy of the mac- and the pc-workspace in an editor but I didn't find any difference except the device name. In pc it's "FirefaceUFX1" and in mac it's "FirefaceUFX23108001"
Andreas
Thanks, we'll check.
Andreas
What happens if you append .tmws(workspace) or .tmss(snap shot) to the file?
RME Fireface UFX
Mac Mini 2.6 GHz 16 GB Ram Areca RAID | MacBook Pro 2,2 GHz 16 GB Ram | OS 10.10.5
It has the extension tmws/tmss but I can't select the file. It is grey. Tmws files which I have created with the mac are not grey and I can load these files. only the files from pc are grey and not selectable.
Strange indeed. HeadScratch
Lets wait and see what MC has up his sleeve.
RME Fireface UFX
8
The ability to read PC files on a Mac has not been implemented yet, it is scheduled for the next version. The files itself are identical, but the Mac does not see them as 'Mac' files. The usual paranoia...
And there we have it folks. :-)
RME Fireface UFX
10
Temporary Workaround
If you need to load a Windows Snapshot or Workspace file into Mac TM FX:
- copy the file into a Mac folder (not FAT or NTFS)
- open the console (Terminal) to set the file type to Mac. Process:
- change to the file's folder (cd to change, ls to show the content of a folder)
- type the command: 'SetFile -t tmws filename.tmws' in case of a Workspace file.
- type the command: 'SetFile -t tmsu filename.tmsu' in case of a Snapshot file.
- check the new metadata of the file with the command 'mdls filename.tmws' or 'mdls filename.tmsu'
Thank you. Now I can load my Basic workspace with all my snapshots which I have created on my PC. Very nice smile
Andreas
